- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello, I've been given this CCA to program, it contains a Cyclone V, 5CEFA5.
The config memory is 1.8V, so the programming bank 3A is set to 1.8V.
VCCIO3A is 1.8V, VCCPGM is 1.8V.
But, it looks like VCCPD3A is tied to 1.8V. I know it should be set to 2.5V.
I am having no luck connecting via JTAG.
Is this VCCPD3A being tied to 1.8V the reason why? And is there anyway to fix this without redoing the entire board?
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Sure, here are sections of the schematic with the JTAG connections and the power connections
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Apologize for the delay in response.
Per your statement below;
'it looks like VCCPD3A is tied to 1.8V. I know it should be set to 2.5V.'
Please clarify. Do you mean it is set automatically to 1.8V?
Any error message you get?
Can you explain further.
Aiman
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
In the attached schematic above, you can see there was an error in the connection. The pin VCCPD3A is tied to 1.8V, when, according to the pin connection guidelines PCG-01014-3.2, the PD pins should not be less than 2.5V.
When I attempt to connect to the FPGA via JTAG, I get a JTAG error. I am wondering if this voltage pin is the reason why. And, if there is anything I can do to get around this.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Yes, the VCCPD3A is giving you the error. You need to follow the pin connection guidelines for this case. Please set is to 2.5V and above per recommended by the guidelines.
Aiman
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
