D5M and LTM
Hello all,
Does anyone know how to interface the two? Make the live display of D5M show on the LTM using ALTERA-De2?
We are able to capture and display image from D5M to VGA Monitor but on the LCD-display.
Thanks!
bump! I need help with this as well.
edit: figured out how to display the camera image on LTM, and capture. But now how do I save image to PC or SD card?
The combo board should come with a CD and on the CD should be a folder named "3in1_lab". Copy this into your Quartus II folder, or anywhere but the cd. Then open quartus II... open existing project... DE2.qpf file... compile... program. This should pop up the image on the LTM. Then open DE2_3in1_Quick_Start.pdf in the Manual\DE2 folder. This give you a basic demo test you can do.
hello,
I want also to diplay image captured by the camera on the LTM on an Altera DE2,
I don't find the folder that you cite,
Could you please tell me how to make such project.
Thank
M.
