Hi, my project uses stratx3 insides ddr3 controller w/UniPHY,
on Fitter lots of 174068 and 174058 errors are appared.
Error (174052): I/O "mem_dq[0]" has dynamic termination control connected, but does not use parallel termination
that repeats for
mem_dq[0] ~ mem_dq[31]
mem_dqs[0] ~ mem_dqs[3]
mem_dqs_n[0] ~ mem_dqs[3]
Error (174068): Output buffer atom "ddr3_ip:U_ddr3_ip|ddr3_ip_0002:ddr3_ip_inst|ddr3_ip_p0:p0|ddr3_ip_p0_memphy:umemphy|ddr3_ip_p0_new_io_pads:uio_pads|ddr3_ip_p0_altdqdqs:dq_ddio[2].ubidir_dq_dqs|altdq_dqs2_ddio_3reg_stratixiii:altdq_dqs2_inst|obuf_os_0" has port "SERIESTERMINATIONCONTROL[0]" connected, but does not use calibrated on-chip termination
this repeats for
dq_ddio[0] ~ dq_ddio[3]
approx. 1100 errors in Fitter process.
Is there any way to solve this?
IIRC, you had to run a Tcl script to create all the I/O assignments needed to work with the IP. Did you run that script?
連結已複製
Does the errors have been resolved after applying tcl script as mentioned by sstrell?
The tcl script should be able to set the IO standard and signal termination for DDR IP.
Please let me know if you are still facing the errors.
Adzim
