Programmable Devices
21615 Discussions
DDR2 Read Issue in Cyclone III
I've instantiated a DDR2 SDRAM HPC using a Cyclone III. We've simulated the design and it works as expected. Using the hardware and SignalTap, I can do a write, and see the data on the mem_dq lines. When I do a read, I see the data come back on the mem_dq lines but the data is never on the local_rdata(255:0) bus. I believe the Quartus II version is 9.1. We are also using the half-data rate version. The DDR2 SDRAM is a PC-5300, 4GB Micron SO-DIMM. I'm thinking that I have a DDR2 controller issue. We are passing calibration because the ctl_cal_sucess line is high and local_init_done goes high after that.
Any thoughts? Any one else seeing this?
Thanks!
Hello dtschindel,
I would like to ask you if you could solve this problem. If yes, How did you solve it?
I am having the same situation.
local_rdata = zero
Thanks in advance,
Juan
Juan,
We could never get the Altera DDR2 Controller to work. We ended up writing our own DDR2 Controller for the Cyclone III.
Hello dtschindel,
...about the simulation and the local_rdata bus.
In my case I didn't see any data because I was forgetting to use the memory model in the Quartus II settings.
After I added the simulation model together with the test_bench file, I could see the local_rdata working.
Maybe is interesting for you.
Juan
Hallo,
I am writing again to update my last comment.
What I wrote previously is valid for:
<variation name>_example_top_tb.vhd
<variation name>_mem_model.vhd
However, I was trying use my own test bench just using the memory model. Then It did not work.
Apparently the solution to this is to modify the _example_top_tb.vhd and integrate it with your design. Or read carefully this testbench and add all the memory parameters for the functional simulation.
Right now I am testing and at least there is result from the local_rdata bus in simulation. However, it is not stable. After few microseconds it is now showing any result.
I am a bit confused with this simulation. However there must be a solution.
Juan
Hello again,
I just wanted to add the simulation error.
Maybe if someone else has had this problem can give me a hand.
Find attached the simulation wave.https://www.alteraforum.com/forum/attachment.php?attachmentid=6692
Juan
I can think of two possibilities for those 'X':[list][*]you have a second driver in your testbench that forces a different value for local_rdata[*]you are reading an address that hasn't been initialized[/list]Do you have any error message or warning in the Modelsim console?
Dear Daixiwen,
Thanks for your reply.
I have tried both.
1. I added by hand all the necessary files (from the memory controller ip core) and made sure that no other driver was interfering.
2. About the reading addresses. I am simply incrementing the address by 2. The address has this format: BANK-ROW-COL
I would like to ask you for a further explanation of the address initialization. Maybe I still don't have this clear.
In the Modelsim console I only get warning messages.
Juan
I forgot to write something,
I get an error after a while that stops the simulation.
This is the error:
# ** Failure: --- Data could not be written, increase array depth or use full memory model ---
I have tried to change the memory_model to the full_memory_model but is not working. Is not even compiling.
Juan
