Programmable Devices
21595 Discussões
DE2-115 ethernet-to-PC
Colaborador honorário II
1.642 Visualizações
Hi ,
Is there a example for DE2-115 board to have 2-way communication via ethernet with a PC . Or if someone can suggest any tutorial to build such a SOC design on this board . An example that dosent require gateway in between .
4 Respostas
662 Visualizações
Take any example that includes ethernet and build simple socket server from examples in Eclipse
662 Visualizações
And what should i run on PC a sniffer or a server application ?
My PC has vista on it , so when nios wants to establish a comm link , how will it get a ip address , vista will assign to it or do i have write some application for that ?
662 Visualizações
Assign a static address to the application and recompile the example project. Since the example is called "Simple Socket SERVER", so You need a client on PC. You may also run a sniffer to check packets.
662 Visualizações
Hi ,
I see four example projects in web_server folder :
DE2_115_WEB_SERVER_MII_ENET0
DE2_115_WEB_SERVER_MII_ENET1
DE2_115_WEB_SERVER_RGMII_ENET0
DE2_115_WEB_SERVER_RGMII_ENET1
Which one is the socket server ?
Responder
