Programmable Devices
21182 Discussions
Dashboard in System Console
Looks like using a Dashboard in System Console is a great way to debug hardware. I am able to write TCL commands to create the dashboard, show the dashboard, add buttons etc. But I have difficulty figuring out how to organize the code (into functions instead of just lines of TCL code).
I am starting out simple, just two buttons and an LED. Start Motor, Stop Motor and Motor_Running LED
This is what I have as a starting point:# ################################################################################## Motor Control
set dash_path [add_service dashboard my_dash "My Dash" "Tools/My Dash"]
# Set dashboard visible
dashboard_set_property $dash_path self visible true
dashboard_add $dash_path G1 group self
dashboard_set_property $dash_path G1 title "Motor Control"# Add Button for Start Motor, Stop Motor
dashboard_add $dash_path BtnStart button G1
dashboard_set_property $dash_path BtnStart text "Start Motor"
dashboard_set_property $dash_path BtnStart onClick
[list StartMotor "Running"]
dashboard_add $dash_path BtnStop button G1
dashboard_set_property $dash_path BtnStop text "Stop Motor"
dashboard_set_property $dash_path BtnStop onClick
[list StopMotor "NotRunning"]
# Add LED to show if Motor is running
dashboard_add $dash_path LEDRunning led G1
dashboard_set_property $dash_path LEDRunning text "Motor Running"
dashboard_set_property $dash_path LEDRunning color green_off
Question 1:
How do I organize this code (maybe into a function called Init), then how do I call it from System Console
Question 2:
When Start Motor is pressed, on click shall call a function. Should I keep the function the same file?
Question 3:
LED should be turned on by Motor-Start, turned off by Motor-Stop
Appreciate any help or advice
