Hi everybody,
In my project I have a FPGA module which reads inputs from INPUT_RAM and stores outputs in OUTPUT_RAM (both rams are altsyncram memories). Inputs are computed in a Linux application running on the HPS and this application needs outputs produced by the FPGA module. So the dataflow should be something like this: 1) HPS computes inputs 2) inputs are transferred from hps to input_ram 3) FPGA module computes outputs and stores them in OUTPUT_RAM 3) outputs are transferred from output_ram to hps 4) HPS uses outputs for its purposes I've successfully managed to map INPUT_RAM and OUTPUT_RAM as Avalon MM slaves in the HPS memory space (with mmap()...) but this approach is too slow. I think I should use the f2h_sdram interface to transfer data with a SGDMA or a mSGDMA controller, am I right? Can someone give me a easy explanation about this possibility? Thank you in advance!Link Copied
