21611 Discussions
Default Termination of Stratix 10 Single Ended IO
HBhat2
New Contributor II
What will be the default Termination resistance of Stratix 10 FPGA GPIO when configured as i) Input ii) output?
With Regards,
HPB
SreekumarR_G_Intel
Hello , For the single ended IO standard such as LVCMOS or LVTTL internal termination resistor is not supported . From the table 9 in the below link shows it supported channel. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-gpio.pdf Also refer Table 4 and Table 5 supported programmable feature and default state for each IO stand's. Thank you , Regards, Sree
SreekumarR_G_Intel
HBhat2
New Contributor II
Thank you for your reply.
With regards,
HPB
