Hi all,
As we know "logic" data type has 4 states = 0, 1, X & Z, where as "bit" has only 2 states = 0 & 1. Generally we can see use of "logic" as data type for all kind of signals on internet :rolleyes:. But I have read in book that for 2 states logic we can use "bit" as datatype. So, my question is, 'can we use "bit" data type for those signals like clock or reset which have only 2 states 0 or 1 ?.' :confused: If no then why we can not use it, and if yes then what is advantage of using "bit" over "logic". module test_example ( input bit clk , // system clock input bit reset_n // system reset ); In this is example I have use bit as datatype for clk and reset_n signal. because it is obvious that clock can not be X or Z. So there are many signals that will not be X or Z then why we used logic datatype for those instead of bit. I hope I am clear with my doubt. If anybody has answer for my question, please explain me. All answers are welcomed here..:)链接已复制
4 回复数
Most people use logic when they could have used bit. The advantage of using logic is that you will see unknowns in simulation if something hasnt been given a value, or you get multiple drivers somewhere. With bit, errors may not be so obvious as X will not propogate and you'll only get a '0'.
But you are right, bit and reset should always be '1' or '0', so having them as bit wont really hurt.--- Quote Start --- As we know "logic" data type has 4 states = 0, 1, X & Z --- Quote End --- std_logic data type has 9 states: "U, X, 1, 0, Z, W, L, H, - " u: Uninitialized x: Unknown 1: Logic 1 0: Logic 0 Z: High impendance W: Weak signal, can't tell if it should be 0 or 1 L: Weak signal that should probably go to 0 H: Weak signal that should probably go to 1 -: Don't care. --- Quote Start --- In this is example I have use bit as datatype for clk and reset_n signal. because it is obvious that clock can not be X or Z. --- Quote End --- In your example, U state can be useful if you forget to initialize a signal in your component testbench.
--- Quote Start --- std_logic data type has 9 states: "U, X, 1, 0, Z, W, L, H, - " u: Uninitialized x: Unknown 1: Logic 1 0: Logic 0 Z: High impendance W: Weak signal, can't tell if it should be 0 or 1 L: Weak signal that should probably go to 0 H: Weak signal that should probably go to 1 -: Don't care. In your example, U state can be useful if you forget to initialize a signal in your component testbench. --- Quote End --- The OP is asking about Verilog. Std_logic is a VHDL concept.
