21611 Discussions
Difference between "logic" and "bit" data types.
Hi all,
As we know "logic" data type has 4 states = 0, 1, X & Z, where as "bit" has only 2 states = 0 & 1.
Generally we can see use of "logic" as data type for all kind of signals on internet :rolleyes:. But I have read in book that for 2 states logic we can use "bit" as datatype.
So, my question is, 'can we use "bit" data type for those signals like clock or reset which have only 2 states 0 or 1 ?.' :confused:
If no then why we can not use it, and if yes then what is advantage of using "bit" over "logic".
module test_example
input bit clk , // system clock
input bit reset_n // system reset
In this is example I have use bit as datatype for clk and reset_n signal. because it is obvious that clock can not be X or Z. So there are many signals that will not be X or Z then why we used logic datatype for those instead of bit.
I hope I am clear with my doubt. If anybody has answer for my question, please explain me. All answers are welcomed here..:)
Most people use logic when they could have used bit. The advantage of using logic is that you will see unknowns in simulation if something hasnt been given a value, or you get multiple drivers somewhere. With bit, errors may not be so obvious as X will not propogate and you'll only get a '0'.
But you are right, bit and reset should always be '1' or '0', so having them as bit wont really hurt.
--- Quote Start ---
--- Quote End ---
std_logic data type has 9 states: "U, X, 1, 0, Z, W, L, H, - "
u: Uninitialized
x: Unknown
1: Logic 1
0: Logic 0
Z: High impendance
W: Weak signal, can't tell if it should be 0 or 1
L: Weak signal that should probably go to 0
H: Weak signal that should probably go to 1
-: Don't care.
--- Quote Start ---
--- Quote End ---
In your example, U state can be useful if you forget to initialize a signal in your component testbench.
--- Quote Start ---
u: Uninitialized
x: Unknown
1: Logic 1
0: Logic 0
Z: High impendance
-: Don't care.
--- Quote End ---
The OP is asking about Verilog. Std_logic is a VHDL concept.
thank you, Tricky for your reply.
And yes JRL this question is about Verilog I am failed to mention that.
