21615 Discussões
Does Altera provide a synchronization chain megafunction for asynchronous inputs
Colaborador honorário II
1.823 Visualizações
It is possible to write a synchronizer chain to synchronize incoming asynchronous signals and prevent metastability. It shall be a few lines of code. Does Altera have a special megafunction to do this or atleast some guidelines so Quartus understands that we are trying to infer a synchronization chain?
3 Respostas
691 Visualizações
Volume 1 of the Quartus Prime handbook: Managing Metastability:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/qts-qpp-5v1.pdf
Since it's only a few lines of code to add registers, I don't think an IP is necessary.
691 Visualizações
--- Quote Start ---
--- Quote End ---
Make your own, it is not hard. Define a verilog module that has CLK, IN, and OUT ports, and internally does an N-rank pipeline delay synchronizer between IN and OUT based on CLK. Then you can instantiate this module however many times you want.
For extra credit you can add a parameter input that specifies the number of levels of delay you want (defaulting to two, for example) but allows you do parameterize the module, if needed.
And you could make the IN and OUT be programmable width, instead of just a default of one bit wide.
691 Visualizações
If the incoming signals are a bus of common signals, your best using dcfifo
Responder
