21615 Discussions
Does repeater/retimer be need when Arria10 GX FPGA used in backplane application?
XG_Kang
two boards are assembled on a backplane with a distance about 30cm. Two Arria10 GX FPGA are located on these two board seperately, connecting to each other with Arrria 10 GX transceiver。Does repeater or retimer be need in this application? the data rate is about 8Gbps。
Deshi_Intel
This is a like chicken and egg question.
The answer lies on how good is your board and back plane signal integrity performance to decide whether additional repeater/retimer is required or not
My recommendation is pls run board simulation to evaluate your system transmission line signal integrity performance to decide whether you need additional chip to boost signal quality or not
dlim
Deshi_Intel
dlim
