21602 Discussions
Does the ddr3 descrete components' command & address signals need termination resistors for c10?
WLin30
I have design a board c5+descrete ddr3 component which command & address signals do not have termination resistors which run ok. I am not sure wheter C10  also ok for such design.
AdzimZM_Intel
The DDR3 discrete components' command & address signals are required the termination resistor.
In Cyclone 10, you can use the internal termination scheme such as on-chip termination (OCT) and on-die termination (ODT) instead of external termination resistor.
You can always refer to Cyclone 10 EMIF User Guide in the link below.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20116.pdf
May I know whether you setup the OCT and ODT on your design Cyclone V with DDR3?
WLin30
Do you mean that by setting Cyclone10's OCT/ODT that need not external termination resistor?
WLin30
If yes, how to set the EMIF's parameters?
AdzimZM_Intel
Hi Sir,
You can set your EMIF's parameter according to your memory spec and datasheet.
For the OCT/ODT, you are encourage to perform on board simulation to get the optimal value.
As I stated in my previous comment, you can always refer to the Cyclone 10 EMIF User Guide to setup your EMIF's parameter.
AdzimZM_Intel
Hi Sir,
Do you have any question regarding to this topic?
Adzim
AdzimZM_Intel
Hi WLin30,
I hope you are doing well.
I have to close the case since you don't have further question for this case.
You can always file a new case if you get the problem or issue in using the Intel product.
Thank you for using Intel Community.
Adzim
