21602 Discussions
Looking for help on constraint syntax
GD76
There is a setup slack violation (see attached). The timing violation at RAM_CONTROL:i13|q3 to DSACK1. We are off by 2.477ns. Looking to understand what syntax for CPLD can be constructed to constraint the path.
Adding the SLOW_SLEW_RATE to the IO in DSACK1 in assignment editor and setting it as OFF works. But looking for a solution more embedded in making the tool route internal path. Any help apprecieted.
sstrell
If I'm reading your document correctly, you're transferring between a 40 MHz clock domain and a 20 MHz clock domain.  As such, you need a multicycle timing exception in your .sdc file.  Going from a faster to a slower domain usually requires a -start multicycle to select the correct launch edge for the setup and hold analysis:
set_multicycle_path –from SYSCLK –to CLK20MHZSYS_ext –setup –start 2
set_multicycle_path –from SYSCLK –to CLK20MHZSYS_ext –hold –start 1
sstrell
GD76
The CPLD gets 20MHz clock. The SYSCLK is 20MHz. Not sure where you got the 40MHz from.
sstrell
Your launch edge time is at 25, so I thought it was 40 MHz.  Can you show a screenshot of the waveform view in your timing analysis?
GD76
Here is the waveform. So the clock need to delayed by 50ns.
sstrell
So you're launching on the falling edge and you want to latch not on the next rising edge but the rising edge after what's in your screenshot?  So a period and a half?  Maybe:
set_multicycle_path –fall_from SYSCLK –to CLK20MHZSYS_ext –setup –end 2
set_multicycle_path –fall_from SYSCLK –to CLK20MHZSYS_ext –hold –end 1
GD76
DSACK1 is launching at falling edge, but want delay it to next falling edge. In this case half-period is 25ns, so 50ns.
So, I have  external clock as 50ns, half-period 25ns
create_clock -name {SYSCLK} -period 50.000 -waveform { 0.000 25.00 } [get_ports {SYSCLK}]
From the above, creating a virtual clock
create_clock -name {CLK20MHZSYS_ext} -period 50.000
The signal of interest constraint as below and give setup slack timing violation. How to make this delayed?
set_output_delay -clock CLK20MHZSYS_ext -max 7.5 [get_ports {DSACK1_n}]
set_output_delay -clock CLK20MHZSYS_ext -min 0.5 [get_ports {DSACK1_n}]
Then tried add this but still give violation
set_output_delay -clock CLK20MHZSYS_ext -clock_fall 50.000 [get_ports {DSACK1_n}]
sstrell
-clock_fall is a switch indicating, for output delay, that data is captured on the falling edge of the virtual clock.  I'm not sure why you have "50.000" there.  You would still need -max and -min with 7.5 and 0.5, respectively.
So I'm still not clear what you want.  Are you saying you want this signal launched by a falling edge (SYSCLK) and latched by the next falling edge of CLK20MHZSYS_ext?  If you clarify exactly what edges you want to use for launch and latch, maybe even a diagram, that would help.
