21605 Discussions
Drive strength settings
Hello:
Just starting with FPGA design
When the FPGA (cyclone II) drives pins into a device with a specific loading value (i.e 10pf) , is there a calculation or rule thumb to estimate what the drive strength should be set in Quartus for those pins? I know Quartus defaults to maximum and sometimes not all signals are available to connect a scope. Other than simulation, is there way to estimate this?
thank you
No one has any hint for this??
thanks in advance
There can't be a rule of thumb because the best setting also depends on signal speed and required rise time respectively acceptable signal delays. I usually choose minimum current for general purpose I/O, higher values possibly for clock lines or fast memory interfaces.
--- Quote Start ---
--- Quote End ---
I think, it's sufficient to connect one signal to an oscilloscope to see the basic effects of current strength settings.
--- Quote Start ---
--- Quote End ---
I thought based on the parameters that you indicated (rise time , load capacitance, etc) that an estimated calculation can be made as a start up value. There are few cases as well where there is no chance to get a test point to put a scope on a particular signal. It will be nice in this case to use a theorical estimation instead of using the default setting even if the system is running ok.
thanks
You can extract the exact output characteristic for each current strength setting from the IBIS files and calculate the respective dynamical response or use a tool, that does the calculation.
--- Quote Start ---
--- Quote End ---
Would you mind elaborating in what tools and a little more details on how you do this exactly?
thanks again
A simple option is to calculate a (dynamic) output impedance from dV/dI gradients in Ibis files. Ther are also signal integrity tools that import Ibis data, but I don't use them.
