21608 Discussions
Dual Configuration IP does not trigger reconfiguration in MAX 10
MJone6
I have a design using 10M16SAU169I7G, with an instance of the remote_configuration IP. The nCONFIG pin is enabled like the NIOS example, and using some external pin logic, I can select and configure both images. When I try to reconfigure internally, I have proven that config_sel_overwrite and config_sel are working by asserting them and setting the nCONFIG pin low externally. But when I issue a trigger reconfiguration internally using offset 0 bit 0, the device does not reconfigure. Using signal tap I see the RU_nCONFIG logic being asserted.
I have tried disabling nCONFIG pin just in case it overrides, but that does not work. Also, the NIOS example enables it.
I have looked through the NIOS example and can't find any clues. That example is for a 10M50, and I am using a 10M16. My understanding is the only device this does not owrk on is a 10M02.
Somehow there must be some configuration parameter or subtle constraint that is preventing RU_nCONFIG from working, or somehow the device reconfigures and then reconfigures again to image 0 without me knowing.
The reset given to the Dual Configuration IP Core comes from a pin outside the FPGA. Therefore, eventually it is tristated and the external signal is ignored. I doubt the IP Core would issue a reconfiguration based on any activity on its pins during the loading of the image. As an experiment, I tied the Core's .nreset to the pll_lock and retested and there was no change in behavior.
Another thing I tested was this. The debugging process means I have loaded an A/B image. I am using JTAG to load a .sof with Signal Tap enabled. I tested after a power up without the JTAG load just in case the JTAG load interfered with reconfiguration. No change in behavior.
I am looking for any ideas or known working project to compare with.
Nooraini_Y_Intel
When using the Dual Boot IP, you should enable the CONFIG_SEL pin options to determine which image the MAX 10 need to be boot up. Then use the config_sel_overwrite bit and config_sel bit to switch between the image 0 and 1 without power cycle.
Did you program the MAX10 with image 0 and image 1 from the beginning then whenever there is a failure in one of the image it should revert to the other image? How do you identify the difference between image 0 and image 1 in the first place? I suggest that you should have 2 different images showing different function for as image 0 and image 1 respectively. This would help to show different image being load into the MAX 10 when power up by CONFIG_SEL pin and by the Dual Boot IP.
1. Program the MAX 10 CFM0 and CFM1/2 with the .pof (2 different .sof file to help showing different image) via the Quartus programmer.
2. Then test the CONFIG_SEL pin to boot the MAX 10 with image 0 and image 1. This will show you the correct expected behavior.
3. Then using the Dual Boot IP, set the config_sel_overwrite bit and config_sel to switch image 0 and image 1.
a. In offset 1, write Bit 0 — set value 1 to this register config_sel_overwrite
b. In offset 1, write Bit 1— writes config_sel either with value 0 or 1 to load from configuration image 0 or 1 respectively.
c. In offset 0, write Bit 0 — set value 1 to trigger reconfiguration.
Nooraini
jozephka99
New Contributor II
You say "...use the config_sel_overwrite bit and config_sel bit to switch between the image 0 and 1 without power cycle.". If I power off the device then power on again which config selection option the device use? The config_sel_overwrite and config_sel bit or the physical CONFIG_SEL pin? I apply RSU to the CFM1 with overwrite and config_sel bit selection, then reconfig the device with reconfig bit. The code that my send works fine. But when I power on the device  after power off the device starts from the old code in the CFM0.
MJone6
Nooraini, thank you for some help.
I enabled dual compressed images. The design has a way to ask the question, what revision are you? And I created two sof images, with two different revisions. Then I combine the two sof files into a pof and program the device by JTAG.
Both images enable all the pins DEV_CLRn, DEV_OE, nCONFIG, nSTATUS, CONF_DONE, and CONFIG_SEL. I have control over these pins via another path in the design outside the FPGA. I can change images using the external pins without any problem, demonstrating the images are good, and that I can see the two different revisions after reconfiguration.
Then I used the IP to try to duplicate reconfiguration. First I used config_sel_overwrite and config_sel, and the nCONFIG pin (external). I have demonstrated that these bits work, because I can change images, and I can change the CONFIG_SEL pin and it is ignored.
Then finally I try to trigger reconfiguration with the IP using offset 0 bit 0 equals 1, and this does not work. So to debug, I created a soft with Signal Tap setup, and load to SRAM. When the bit is set to one, I see alt_dual_boot|ru_rcofig toggle high. This demonstrates that the IP is receiving the offset zero command and issuing the signal.
No doubt there is more logic between this signal and the IP, and it is mixed with the nCONFIG pin, perhaps with an OR gate somewhere. What I don't know is if there is some other setting that must be used to enable ru_config to work, or some limitation on this particular version of the MAX 10, or some external state that effects it, etc. I get the same results on two pieces of hardware. I am using Quartus 17.
MJone6
I'll add to this that I put a scope on STATUS/ and CONF-DONE, and when CONFIG/ is asserted at the pin, I see them go low and high, and when offset 0 bit one is used, these pins do not change state. I did this to ensure there was not a reconfiguration/load of the image combined with a failure. I internal method just fails to trigger.
MJone6
Adding my settings...
set_global_assignment -name FAMILY "MAX 10"
set_global_assignment -name DEVICE 10M16SAU169I7G
set_global_assignment -name TOP_LEVEL_ENTITY i2cspy
set_global_assignment -name ORIGINAL_QUARTUS_VERSION 14.1
set_global_assignment -name PROJECT_CREATION_TIME_DATE "13:40:09 JUNE 26, 2014"
set_global_assignment -name LAST_QUARTUS_VERSION "18.0.0 Lite Edition"
set_global_assignment -name PROJECT_OUTPUT_DIRECTORY output_files
set_global_assignment -name MIN_CORE_JUNCTION_TEMP "-40"
set_global_assignment -name MAX_CORE_JUNCTION_TEMP 100
set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 2
set_global_assignment -name EDA_SIMULATION_TOOL "ModelSim-Altera (VHDL)"
set_global_assignment -name EDA_OUTPUT_DATA_FORMAT VHDL -section_id eda_simulation
# Design Pin Assignments
# General configuration
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT_AND_ROUTING -section_id Top
set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top
set_global_assignment -name UNIPHY_SEQUENCER_DQS_CONFIG_ENABLE ON
set_global_assignment -name OPTIMIZE_MULTI_CORNER_TIMING ON
set_global_assignment -name UNIPHY_TEMP_VER_CODE 2093439050
set_global_assignment -name ECO_REGENERATE_REPORT ON
set_global_assignment -name STRATIX_DEVICE_IO_STANDARD "3.3-V LVCMOS"
set_global_assignment -name CYCLONEII_OPTIMIZATION_TECHNIQUE SPEED
set_global_assignment -name SYNTH_TIMING_DRIVEN_SYNTHESIS ON
set_global_assignment -name OPTIMIZE_HOLD_TIMING "ALL PATHS"
set_global_assignment -name FITTER_EFFORT "STANDARD FIT"
set_global_assignment -name ENABLE_SIGNALTAP ON
set_global_assignment -name USE_SIGNALTAP_FILE i2scope.stp
set_global_assignment -name PHYSICAL_SYNTHESIS_COMBO_LOGIC ON
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_RETIMING ON
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION ON
set_global_assignment -name PHYSICAL_SYNTHESIS_COMBO_LOGIC_FOR_AREA ON
set_global_assignment -name ROUTER_LCELL_INSERTION_AND_LOGIC_DUPLICATION ON
set_global_assignment -name ROUTER_TIMING_OPTIMIZATION_LEVEL MAXIMUM
set_global_assignment -name QII_AUTO_PACKED_REGISTERS "MINIMIZE AREA"
set_global_assignment -name MUX_RESTRUCTURE OFF
set_global_assignment -name ROUTER_CLOCKING_TOPOLOGY_ANALYSIS ON
set_global_assignment -name ADV_NETLIST_OPT_SYNTH_WYSIWYG_REMAP ON
set_global_assignment -name SMART_RECOMPILE OFF
set_global_assignment -name TIMING_ANALYZER_MULTICORNER_ANALYSIS ON
set_global_assignment -name POWER_PRESET_COOLING_SOLUTION "23 MM HEAT SINK WITH 200 LFPM AIRFLOW"
set_global_assignment -name POWER_BOARD_THERMAL_MODEL "NONE (CONSERVATIVE)"
set_global_assignment -name ENABLE_OCT_DONE OFF
set_global_assignment -name USE_CONFIGURATION_DEVICE OFF
set_global_assignment -name INTERNAL_FLASH_UPDATE_MODE "DUAL IMAGES"
set_global_assignment -name CRC_ERROR_OPEN_DRAIN OFF
set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -rise
set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -fall
set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -rise
set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -fall
set_global_assignment -name FLOW_ENABLE_POWER_ANALYZER ON
set_global_assignment -name POWER_DEFAULT_INPUT_IO_TOGGLE_RATE "100 %"
set_global_assignment -name DEVICE_FILTER_PACKAGE UFBGA
set_global_assignment -name DEVICE_FILTER_PIN_COUNT 169
set_global_assignment -name DEVICE_FILTER_SPEED_GRADE 7
set_global_assignment -name VERILOG_INPUT_VERSION SYSTEMVERILOG_2005
set_global_assignment -name VERILOG_SHOW_LMF_MAPPING_MESSAGES OFF
set_global_assignment -name POWER_USE_PVA OFF
set_global_assignment -name POWER_DEFAULT_TOGGLE_RATE "100 %"
set_global_assignment -name ENABLE_BOOT_SEL_PIN ON
set_global_assignment -name ENABLE_CONFIGURATION_PINS ON
set_global_assignment -name ENABLE_DEVICE_WIDE_RESET ON
set_global_assignment -name ENABLE_DEVICE_WIDE_OE ON
set_global_assignment -name AUTO_RESTART_CONFIGURATION ON
set_global_assignment -name STRATIXV_CONFIGURATION_SCHEME "PASSIVE SERIAL"
set_global_assignment -name STATE_MACHINE_PROCESSING AUTO
set_global_assignment -name SAFE_STATE_MACHINE OFF
set_global_assignment -name EXTRACT_VERILOG_STATE_MACHINES ON
set_global_assignment -name PARALLEL_SYNTHESIS ON
set_global_assignment -name ALLOW_POWER_UP_DONT_CARE ON
set_global_assignment -name REMOVE_DUPLICATE_REGISTERS ON
set_global_assignment -name AUTO_CARRY_CHAINS ON
set_global_assignment -name AUTO_CLOCK_ENABLE_RECOGNITION ON
set_global_assignment -name ALLOW_SYNCH_CTRL_USAGE ON
set_global_assignment -name AUTO_RESOURCE_SHARING OFF
set_global_assignment -name USE_LOGICLOCK_CONSTRAINTS_IN_BALANCING ON
set_global_assignment -name SYNTH_CLOCK_MUX_PROTECTION ON
set_global_assignment -name SYNTH_PROTECT_SDC_CONSTRAINT OFF
set_global_assignment -name PRE_MAPPING_RESYNTHESIS OFF
set_global_assignment -name SYNTH_MESSAGE_LEVEL MEDIUM
set_global_assignment -name DISABLE_REGISTER_MERGING_ACROSS_HIERARCHIES AUTO
MJone6
Adding the registers removed during synthesis, in case anyone knows the internal design and can detect a problem.
Nooraini_Y_Intel
Hi MJone6,
Why do you need to control the nCONFIG pin? There is no need to control the nCONFIG pin at all. You only need to set these 2 bit config_sel_overwrite bit and config_sel bit  before triggering the reconfiguration. Did you try to read Read reconfiguration trigger status to check the actual error? Previously I have tested the Dual Boot IP functionin correctly with a simple code as shown in the snippet below:
case 2: /*set CONFIG_SEL overwrite to 1 and CONFIG_SEL to 0*/ IOWR(DUAL_BOOT_0_BASE, 1, 0x00000001); state++; break;   case 3: /*Trigger reconfiguration to Image 0*/ if(IORD(DUAL_BOOT_0_BASE,3) == 0) { IOWR(DUAL_BOOT_0_BASE, 0, 0x00000001); state=0; } break;   case 4: /*set CONFIG_SEL overwrite to 1 and CONFIG_SEL to 1*/ IOWR(DUAL_BOOT_0_BASE, 1, 0x00000003); state++; break;   case 5: /*Trigger reconfiguration to Image 1*/ if(IORD(DUAL_BOOT_0_BASE,3) == 0) { IOWR(DUAL_BOOT_0_BASE, 0, 0x00000001); state=0; } break;
Nooraini
MJone6
I do NOT want to control nCONFIG, it is the only thing that works. My FPGA Verilog basically does this: if(IORD(DUAL_BOOT_0_BASE,3) == 0) { IOWR(DUAL_BOOT_0_BASE, 0, 0x00000001); state=0; } And it DOES NOT WORK. The status returned from offset 3 is ZERO. Yet it DOES NOT WORK. The fundamental problem is I am doing exactly the same thing you do, but it does not work. So the question is what else matters? Everything else in my discussion about what I did is an attempt to find out what else matters that is not obvious. So I did lots of experiments, like disable nCONFIG, used Signal Tap to trace the signals down to ru_... and see it actuate and it looks good. So I am ASSUMING, there is some SETTING in the project that matters. So I even looked at all the settings in the Nios project for clues and everything was how I set my project. It could even be some crazy synthesis error, device bug, not supported and not documented that my 10M16 does not support it, etc. I know it is hard to believe I am not doing just what you are showing, but I am, because I can see the signal assert in the IP to reconfigure and I can see the status is ZERO with Signal Tap as well. Also, I have proven that the config_sel_overwrite and config_sel work. It is just that reconfigure bit does nothing. And there is no visibility into how the Hard IP is designed and other logic it might be connected to, so it requires an Intel person to look into that for other dependencies that are not well documented. Mike
Nooraini_Y_Intel
Hi MJone6,
Did you try to read Read reconfiguration trigger status to check the actual error? I have migrated the existing AN741 example design from the v16.1.0 design store (in the link below) into Quartus Prime v18.0 today and tested successfully.
https://fpgacloud.intel.com/devstore/platform/16.1.0/Standard/max10-remote-system-upgrade-rsu-over-uart-for-nios-ii-processor/
You can refer to the attached .zip file which contain the designs. Both the .qar designs has simple LEDs design to indicate different image between factory image (CFM0) and application1 image (CFM1/2). There is no issue with the Dual Boot IP that I have tested today. You can use the example design to compare with yours if there are any difference settings.
Nooraini
RVadl2
@Nooraini_Y_Intel  Hi, I do not have the Nios 2 process license. I would be great if you can post the .pof files also for the above project which will help us in testing the working of RSU without compiling the project.
Thanks in advance.
MJone6
Hi Nooraini, I looked at state, previous state 1 and 2. Is there some other status I am missing? Can you give the offset and bits for trigger status so I can make sure I am not missing something? All I know of are the states and busy. That said, the states don’t show any failures. I can’t poll fast enough to watch the current state change, but the external pins act as if nothing triggered. Perhaps you can confirm that when a reconfigure is triggered internally, the external status pins should change. Mike
MJone6
I found the problem. In the qdf file is this: set_global_assignment -name ENABLE_NCONFIG_FROM_CORE On I did not know about this file, so it was missed. Where in the Quartus GUI do you set this? Mike
MJone6
I moved the extra line to the qsf file and it still works. UG-M10CONFIG doc says on page 2-9: “By default, the remote system upgrade features is enabled in all MAX 10 devices when you select dual compressed image internal configuration mode. I believe it is a Quartus bug that this extra line enabling internal nCONFIG is not put into the qsf file when you select dual mode. Mike
MJone6
The AN for this will be out of sync with Quartus 17. It generates two RPD files, one for CFM0 and one for CFM1. So I don’t think you need a hex editor. I’ll try to finish the code to write one to flash and see if I can finish this off. Mike
Nooraini_Y_Intel
Hi MJone6,
It is good to know that you are able to resolve the issue at your side. However there is no need to add this assignment into the project design. I have tested my own design in Quartus v18.0 with the Dual boot IP without this assignment and it can still function correctly. I observe that only older Quartus version such as v15.1 and lower will generate .qdf file however newer Quartus no longer do this. There is no such setting in Quartus GUI for this assignment.
The AN741 example design that I provided was originally created in Quartus v15.1 which I migrated into Quartus v18.0. When I created a new design in Quartus v18.0 , no such .qdf file and assignment was generated. Yet, my design can function as expected thus this is not a bug.
You are right about the AN741 is a bit outdated as it was created during Quartus v15.1. Newer Quartus version can generate the .rpd file for CFM0 and CFM1/2 respectively.
Nooraini
MJone6
I can only say it does not work with Quartus 18 in my case. My project started with Quartus 16 and was migrated, etc. Then it was changed to dual image from Quartus 18. This change should have added the ON setting, but it did not. Sounds like a typical context dependent manifestation of a software bug.
