21616 Discussions
EP3C40F324C8N Leakage voltage 1.38V @ pin#U4 .
Kulwiwat
We  have got the new FAR from customer and would like to  return  EP3C40F324C8N for FA. The problem is Leakage voltage 1.38V @ pin#U4 . Could you please review and provide me the FAR numner with ship to address?  Thanks
Farabi
The FAR process need to go through technical investigation first.
Could you please explain what is the details of the pin leakage?
1. How many seeing same issue out of how many produced
2. Methods of leakage measurement
regards,
Farabi
Kulwiwat
We have only 1 pc failed and need to be return for FA.
The failure was confirm by our tester and becnch testing .
All FAULT signals connected with pinU4 of IC U5c, Measurement voltage has found 1.8 V leakage voltage always send out from IC U5 (CPU)  We could suspect that the root cause may came from IC U5 on Eigen PCBA was damaged from.
Measured pin G of Q32 compare with the known good PBCA
  • no any fault measured = 0V and
  • fault measured = 3.3V
Measured Failed PBCA always found leakage voltage 1.38V input triggering from the Eigen PCBA even if the PCBA has no any fault.
Could you please provide us the ship to address? then, we can return this ssupect part to you for further investigation.
Kulwiwat
INTEL-FAE, Could you please update status? Can we retrun the sample to you for further investigation? . Thank you.
Farabi
I will register your case with FAR, will give you the number and address to return.
regards,
Farabi
Farabi
I have filled in few items in the attached Device Problem Report, could you please fill in all the rest of the form?
once completed, please send back to me to email : el.farabi.razali@intel.com
I can only register FAR case once the complete form received.
thank you,
Farabi
Farabi
Hi Kulwiwat,
I will close this forum to control the internal information from public. We will communicate directly via email.
FACR number CI2209-6749.
best regards,
Farabi
