21615 Discussions
EPCQ256 programming error on Cyclone V E Development Kit
MarioSanti
Hello, I would like to know if it's possible to program the "Cyclone V E Development Kit" using the EPCQ256 memory? I tried converting my .sof file to .jic in Quartus, but when I attempt to program the board, I get error 209025. Has anyone else encountered this issue?
Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.
Fakhrul
A few things to clarify:
  1. Physically verify the flash device installed on your board. The part number (e.g., EPCQ256, EPCS128) should be printed directly on the chip.
  2. In Quartus Programmer, use “Auto Detect” to see which devices are recognized on the JTAG chain.
  3. How you convert to the .jic file? When converting your .sof to .jic, be sure to select the exact flash device that matches the part number on your board.
  4. Ensure your board is properly powered and all JTAG connections are secure.
  5. Use a supported version of Quartus (13.1 or newer) when working with EPCQ256.
There are several similar threads with solutions that you may find helpful. Please refer to the links below:
https://community.intel.com/t5/Programmable-Devices/quot-Can-t-recognize-silicon-ID-for-device-1-quot-while/td-p/199210
https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/cyclone-v-flashing-issue-with-EPCQ256-and-QSPI/m-p/187195?profile.language=es
https://community.intel.com/t5/Programmable-Devices/How-to-solve-silicon-id-error/td-p/267644
https://community.intel.com/t5/Intel-Quartus-Prime-Software/problem-JTAG-programming-an-EPCQ256/td-p/105767
Fakhrul
Fakhrul
As we haven't received a response to our previous notification, this thread will be transitioned to community support. We hope all your concerns have been addressed. If you have any new questions, please feel free to open a new thread to receive support from Intel experts. Otherwise, community users will continue to assist you here. Thank you.
