Programmable Devices
21615 Discussions
EPCS memory (1MBIT) not response
Sorry for my bad English.
I have a problem with communication between ATMEGA128 and EPCS memory (1MBIT).
Result product may be a altera programmer constructed from FTDI-ATMEGA-EPCS.
Memory not responce for any operation code. I try next one:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6491 https://www.alteraforum.com/forum/attachment.php?attachmentid=6492 https://www.alteraforum.com/forum/attachment.php?attachmentid=6493
First image is read status, second image is write enable and third image is write status. This images are from osciloscope measure at real device.
Could anyone help??? Thak you very much
source code:
main loop:
char registr = 0b00000011;
while(1){
_delay_ms(200);
write_enable();
write_status(registr);
read_status();
void write_enable(void){
char intsr = 0b00000110;
PORTD &= ~(1<<NCS); // CLR NCS
_delay_ms(20);
for(int i = 7;i>=0;i--){
_delay_us(3);
PORTD &= ~(1<<DCLK); //clear CLK
_delay_us(1);
if((intsr&(1<<i))!=0){
PORTG |= (1<<ASDI); // setb ASDI
}else {
PORTG &= ~(1<<ASDI);// clr ASDI
_delay_us(3);
PORTD |= (1<<DCLK); //data load at rising edge
_delay_us(1);
PORTD &= ~(1<<DCLK); //clear clk
_delay_us(3);
PORTD |= (1<<NCS); // SETB NCS
void write_status(char registr){
char intsr = 0b00000001;
_delay_ms(20);
_delay_us(3);
_delay_us(3);
}else {
_delay_us(3);
_delay_us(3);
_delay_us(3);
if((registr&(1<<i))!=0){
}else {
_delay_us(3);
_delay_us(3);
_delay_us(3);
void read_status(void){
char intsr = 0b00000101;
_delay_ms(20);
}else {
_delay_us(3);
_delay_us(3);
_delay_us(3);
_delay_us(3);
_delay_us(3);
_delay_us(3);
Does anyone know how to comunicate with memory and where may be a problem?? Probably it will just be an error in timing or sequence of commands.
