Sorry for my bad English. I have a problem with communication between ATMEGA128 and EPCS memory (1MBIT). Result product may be a altera programmer constructed from FTDI-ATMEGA-EPCS. Memory not responce for any operation code. I try next one: https://www.alteraforum.com/forum/attachment.php?attachmentid=6491 https://www.alteraforum.com/forum/attachment.php?attachmentid=6492 https://www.alteraforum.com/forum/attachment.php?attachmentid=6493 First image is read status, second image is write enable and third image is write status. This images are from osciloscope measure at real device. Could anyone help??? Thak you very much ------------------------------------ source code: main loop: char registr = 0b00000011; while(1){ _delay_ms(200); write_enable(); write_status(registr); read_status(); } -------------------------- void write_enable(void){ char intsr = 0b00000110; PORTD &= ~(1<<NCS); // CLR NCS _delay_ms(20); for(int i = 7;i>=0;i--){ _delay_us(3); PORTD &= ~(1<<DCLK); //clear CLK _delay_us(1); if((intsr&(1<<i))!=0){ PORTG |= (1<<ASDI); // setb ASDI }else { PORTG &= ~(1<<ASDI);// clr ASDI } _delay_us(3); PORTD |= (1<<DCLK); //data load at rising edge } _delay_us(1); PORTD &= ~(1<<DCLK); //clear clk _delay_us(3); PORTD |= (1<<NCS); // SETB NCS } ----------------------------------------- void write_status(char registr){ char intsr = 0b00000001; PORTD &= ~(1<<NCS); // CLR NCS _delay_ms(20); for(int i = 7;i>=0;i--){ _delay_us(3); PORTD &= ~(1<<DCLK); //clear clk _delay_us(3); if((intsr&(1<<i))!=0){ PORTG |= (1<<ASDI); // setb ASDI }else { PORTG &= ~(1<<ASDI);// clr ASDI } _delay_us(3); PORTD |= (1<<DCLK); //data load at rising edge } for(int i = 7;i>=0;i--){ _delay_us(3); PORTD &= ~(1<<DCLK); //clear CLK _delay_us(3); if((registr&(1<<i))!=0){ PORTG |= (1<<ASDI); // setb ASDI }else { PORTG &= ~(1<<ASDI);// clr ASDI } _delay_us(3); PORTD |= (1<<DCLK); //data load at rising edge } _delay_us(3); PORTD &= ~(1<<DCLK); //clear clk _delay_us(3); PORTD |= (1<<NCS); // SETB NCS } ------------------------------------ void read_status(void){ char intsr = 0b00000101; PORTD &= ~(1<<NCS); // CLR NCS _delay_ms(20); for(int i = 7;i>=0;i--){ if((intsr&(1<<i))!=0){ PORTG |= (1<<ASDI); // setb ASDI }else { PORTG &= ~(1<<ASDI);// clr ASDI } _delay_us(3); PORTD |= (1<<DCLK); //data load at rising edge _delay_us(3); PORTD &= ~(1<<DCLK); //clear CLK _delay_us(3); } _delay_us(3); for(int i = 7;i>=0;i--){ PORTD &= ~(1<<DCLK); //clear CLK _delay_us(3); PORTD |= (1<<DCLK); //data load at rising edge _delay_us(3); } PORTD |= (1<<NCS); // SETB NCS }- Tags:
- Memory
Does anyone know how to comunicate with memory and where may be a problem?? Probably it will just be an error in timing or sequence of commands.
Topic Options
