21610 Discussions
EPCS128 Programming
i want to program epcs128 via jtag
what should i do?
What board you are using?
You can use .jic file and USB blaster cable. Go to File-> Convert Programming File. Convert your .sof file to .jic.
i design my own board
i use cylcon v 5ceba9f23c8
i programming fpga via jtag (its work but very slowly)
after that i convert sof file to jic and start to programming when the programming reach 97%
its failed !!!
What error message you get when it fails?
I recomend reading "Configuration, Design Security, and Remote System Upgrades in Cyclone V" chapter from Cyclone V handbook.
i find problem my problem is power
now i fixed but i now another problem
when i programm sof file everything is ok
but when i programm jic file nothing happend (jic file programm and reach to 100%)
(i read Configuration, Design Security, and Remote System Upgrades in Cyclone V" chapter from Cyclone V handbook)
i find my problem if anyone have problem like me can contact me
email:khatibshahidi.hamid@gmail.com
--- Quote Start ---
--- Quote End ---
What's the problem you met? And how did u deal with it?
Do u think you can use other chip to replace epcs128 to save cost? EPCS128 is too expensive.
--- Quote Start ---
--- Quote End ---
all my problem is related to power design i use tps54310
my program file is to big and i need the epcs128
i design DRM
--- Quote Start ---
i design DRM
--- Quote End ---
I mean that you can select other company's part instead of altera's, which has same memory sizes.
yes you can use another brand but not all of them
you should disable id check when you want to programm
also you can use microcontroller for programming
