21600 Discussions
Error: Can't access JTAG chain
Aravindpb
using cyclone v quartus prime lite 16.0
I has been trying to program FPGA but the code is not dump showing some error like can't access JTAG
But i tried in another fpga board code have dumped successfully
i hope there is no problem in the side of JTAG , I don't know where the problem is coming
please let me know where the bug is receiving
Thanks & Regards
Aravind p
AnandRaj_S_Intel
Hi @Aravindpb​
The issue may be due to
  1. JTAG header pins. Check your jtag header pins for ground short or misplacing it.
  2. Power supply. check the power supplies and its connection are following the recommended values as stated in the respective device handbook.
  3. pull-up & pull-down connected to the JTAG pins are following the recommended values as stated in the respective device handbook.
Check the link which address the issue
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03312011_647.html
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
