21615 Discussions
Error: The -novopt option has no effect on this product
Enid_
I first downloaded the latest version of Quartus Prime Lite edition, after runing the simulation wave form editor, I got this error
Error (suppressible): (vsim-12110) The -novopt option has no effect on this product. -novopt option is now deprecated and will be removed in future releases.
# Error loading design
under
**** Running the ModelSim simulation ****
Then I deleted this version and downloaded version 20.1 and I got this error again.
I didn't find any similar case on the internet.
by the way,
*I used the block diagram first and the compilation was successful then I  run the simulation wave form editor.
*My modelSim version is also 20.1.
*The program couldn't find the path to ModelSim at first, so I changed the modelsim path from Tools -> Options -> EDAtools, the path is changed to C:\intelFPGA\20.1\modelsim_ase\win32aloem.
*I am using a MacBook and have installed Quartus in BOOTCAMP. My project file is located in the Onedrive folder.
The whole result:-----------------------------------------------------------------------
C:/intelFPGA/20.1/modelsim_ase/win32aloem/vsim -c -do adder4.do
Reading pref.tcl
# 2020.1
# do adder4.do
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim - Intel FPGA Edition vlog 2020.1 Compiler 2020.02 Feb 28 2020
# Start time: 22:53:50 on Jan 08,2023
# vlog -work work adder4.vo
# -- Compiling module adder4
# Top level modules:
# adder4
# End time: 22:53:50 on Jan 08,2023, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# vlog -work work Waveform1.vwf.vt
# -- Compiling module adder4_vlg_vec_tst
# adder4_vlg_vec_tst
# vsim -novopt -c -t 1ps -L cyclonev_ver -L altera_ver -L altera_mf_ver -L 220model_ver -L sgate_ver -L altera_lnsim_ver work.adder4_vlg_vec_tst
# ** Error (suppressible): (vsim-12110) The -novopt option has no effect on this product. -novopt option is now deprecated and will be removed in future releases.
# End time: 22:53:51 on Jan 08,2023, Elapsed time: 0:00:01
# Errors: 1, Warnings: 0
Error.
ShengN_Intel
In the Simulation Waveform Editor, go to Simulation -> Simulation Settings. Next, delete -novopt to bypass the problem.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ShengN_Intel
Sheng
Enid_
Thank you so much !!! The problem is solved!
NourBadra
Hello , i did this and the output doesn't come only shows x
