Programmable Devices
21598 토론
Error running quartus : Failed to start Core Services: Failed to launch rpcss
명예로운 기여자 II
3,984 조회수
Hi all,
I have a problem to run quartus on my linux, when I simply run it, I have a message like this :
./quartus Abandon
So I modified a little the run script to see where is the problem :
quartus Failed to start Core Services: Failed to launch rpcss
After this I decide to see the rpcss program :
./rpcss Failed to start Core Services: Failed to launch rpcss. 03/04 18:07:52 -> Registry server is currently unavailable (0)
Does someone have an idea on my problem ?
Thanks a lot...
0 포인트
8 응답
명예로운 기여자 II
3,043 조회수
I installed quartus 9.1 on an upto date FC12 system, and it gives me a similar issue on starting quartus
$ which quartus
/tools/altera/9.1/quartus/bin/quartus
$ quartus
19/05 12:41:53 [# 1] ->
RPCSS ServiceMain failed with 1702 (000006a6)
The binding handle is invalid.
Segmentation fault (core dumped)
The quartus logo appears for few seconds and then it dies.
Any ideas which package I need to remove. It seems like RPCSS is a windows issue on googling, is this some thing related to wine. I checked the list of processes using ps, no command name with rpcss. The closest I found are
root 1188 2 0 11:40 ? 00:00:00 [rpciod/0]
root 1189 2 0 11:40 ? 00:00:00 [rpciod/1]
Any ideas?
0 포인트
명예로운 기여자 II
3,043 조회수
i am running web edition 9.1sp2 on FC12 without problems (after removing 2 .so in the Quartus install as mentioned in some other threads).
are you using web or subscription edition? if subscription try running mwcleanup (also in $QUARTUS_ROOTDIR/bin).
0 포인트
명예로운 기여자 II
3,043 조회수
I forgot to paste the solution, now that I got this problem on a new machine, I am posting it here. The Fedora linux distro FC13 (11,12 too) by default puts machine name (abcd here) in /etc/hosts
as first line
127.0.0.1 abcd.domain.com abcd localhost.localdomain localhost
The line should be either
127.0.0.1 localhost.localdomain localhost
or the line commented out altogether to get rid of this error.
You all need machine ip in there.
192.168.1.xx abcd.domain.com abcd
0 포인트
명예로운 기여자 II
3,043 조회수
mine looks like your modified version also, i can't remember if i changed it from default
$ cat /etc/hosts 127.0.0.1 localhost.localdomain localhost ::1 localhost6.localdomain6 localhost6
0 포인트
명예로운 기여자 II
3,043 조회수
Having the same problem; prior to it, 9.1 ran fine on this machine for close to 8 months.
FC12, x64. Ran mwcleanup, didn't help. Any other ideas?
0 포인트
명예로운 기여자 II
3,043 조회수
it was working fine and then just stopped?
must have been a change in a yum update. did you take a look at your /etc/hosts as mentioned above?
0 포인트
명예로운 기여자 II
3,043 조회수
Yep, /etc/hosts look fine. Probably a yum update caused it. I wish I knew how to debug this - MainWin documentation is scarce, and Altera will probably wave it off, since they only support RHEL...
BTW, happens both on 9.1 and 9.1.2; 10.0 and 10.0.1 run fine.
0 포인트
명예로운 기여자 II
3,043 조회수
--- Quote Start ---
as first line
--- Quote End ---
Thank you that solved my problem :)
Details:
I'm running Ubuntu 10.10, and installed Altera NiosII IDE and Quartus (both version 9.0)
my /etc/hosts content was (when Quarts was giving "Segmentation fault"):
192.168.0.57 MirDesktop# Added by NetworkManager
::1 MirDesktop localhost6.localdomain6 localhost6
127.0.1.1 MirDesktop
# The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
When commenting row 3 and 4, everything works fine, my /etc/hosts looks now:
#::1 MirDesktop localhost6.localdomain6 localhost6
#127.0.1.1 MirDesktop
Hope this will help someone :)
Thank you
0 포인트
응답
