21615 Discussions
Ethernet suggestion
ochiang
I am using a Cyclone V SoC FPGA and I would like to inquire about the feasibility of using this component for Ethernet communication at speeds of at least 2.5Gbps.
I am open to using either the HPS or the FPGA Fabric.
I would appreciate any related suggestions, peripheral components, simple architectures, or design examples that you can provide for reference.
Thank you very much.
Jeet14
Unfortunately, we don't have support for 2.5G ethernet support from the HPS or FPGA side on Cyclone V SX device.
On Cyclone V SX SoC FPGA, at HPS side you can use ethernet only 10/100/1000 Mbps.
https://www.intel.com/content/www/us/en/docs/programmable/683126/21-2/ethernet-media-access-controller.html
But in Cyclone 10 GX device, you can use the 2.5G ethernet.
https://www.intel.com/content/www/us/en/docs/programmable/683054/20-1/about-the-1g-2-5g-5g-10g-multi-rate.html
Tiwari
ochiang
Hi Jeet14,
thank you for your reply,
I saw in the documentation that both the Cyclone V Transceiver Native PHY IP Core and the Custom PHY IP Core support GIGE-2.5Gbps PCS. Can't these be used to implement 2.5Gbps Ethernet?
Jeet14
Please refer the below link for the ethernet IP support on Cyclone V SX device.
Find Intel® FPGA Intellectual Property (IP) Cores
This link shows the support for ethernet IP 1G and 10G on Cyclone V but not the 2.5G ethernet IP.
Tiwari
ochiang
Hi Tiwari,
Thank you for your reply,
I instantiated a Native PHY IP within the Cyclone V SX and used the IP Library to set GIGE-2.5Gbps. I can see that the IP sets the Data rate to 3125Mbps on the PMA configuration page (as shown in the image). Doesn't this indicate that the Cyclone V SX is capable of 2.5Gbps Ethernet?
Jeet14
Yes this Cyclone V Transceiver native phy have this configuration but we don't have the ethernet IP from us on cyclone V which can give you 2.5G speed.
example- We have Multirate ethernet IP which supports Arria V device. https://www.intel.com/content/www/us/en/products/details/fpga/intellectual-property/interface-protocols/10g-multirate-ethernet-phy.html
For this you can use the third party IP or you can build your own IP for this.
Tiwari
ochiang
Hi Tiwari,
So, can I implement a simple Ethernet frame processing (MAC Layer) in RTL, then connect the RTL to the Native PHY, and use an external PHY component like SGMII+ (e.g., GPY211) to achieve 2.5G Ethernet? Is this feasible?
Jeet14
Yes, you need to write RTL logic for MAC+PCS & MDIO logic as well for external PHY's then you can directly connect it with XCVR Native PHY 2.5G.
Tiwari
ochiang
Hi Tiwari,
I am very grateful for your information; it has been very helpful to me.
However, I have some additional questions. There is already a Standard PCS within the Native PHY. When I select GigE 2.5G, it sets up to enable PCS 8b/10b. How is this different from the PCS you mentioned? Specifically, what additional PCS functionality do I need to implement? Could you provide some hints?
Are you referring to handling things like Ordered-sets?
Jeet14
You need to define the interface like RX/TX 16-bit GMII in the RTL MAC and connect it to PCS 8b/10b.
Tiwari
Jeet14
Please let me know if you have any other query on this.
Tiwari
ochiang
Hi Tiwari,
Thank you very much for your help. I will continue to research some items related to PCS. Thank you.
Jeet14
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Tiwari
