FPGA VERILOG
Kxyxl_vxly
I am a final year student in mechatronics engineering . My final year project is to build a electronics voting system using DE10 Standard terasIC FPGA board in Quartus Verilog . The components that I need to use is AS608 Fingerprint sensor and 16X2 LCD Display with I2C module. Can You help me on this?
I tried to insert the pins in the pin planner but The pin is not found there . So, I tried to do the qsys in Quartus and it is showing error .I  don't know what to do next.
sstrell
Your system is connected up incorrectly.  This is not how the clock source component is typically used.
But the easiest thing to do with start with a reference design (GHRD).  The CD download for the board has example designs and is linked through Rocketboards: https://www.rocketboards.org/foswiki/Documentation/DE10Standard
Kxyxl_vxly
Can u guide me to connect AS608 fingerprint sensor and 16X2 LCD Display with I2C Module to DE-10 Standard FPGA Board?I am confused about the pin location.Because when I run the pin planner it shows value entered is not a valid location.
_AK6DN_
Valued Contributor II
Go here:
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1081#contents
And look at the documentation that TerASIC provides for that board.
In particular, look at the RESOURCES tab, and at the DE10-Standard SystemBuilder tool you can download.
It is a standalone windows program that can help you configure the I/O definition for the board resources/pinout
that you can then edit/alter as necessary for your project definition.
It will build a .qpf, .qsf, .sdc, and .v template files for you to start with.
You also might look at some of the examples provided on the DE10-Standard CD-ROM image that is provided.
It is very useful, if you don't already have that software and files you should.
TingJiangT_Intel
Hi there, is there any updates on this?
TingJiangT_Intel
Hi there, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
