21613 Discussions
FIFO implementation
Hello Friends,
I am trying to implement a FIFO in the Altera modelsim. Is there any built in primitive for the Arria2GX device that I can use readily ?Can I use the M9K memory block for such an use? If yes , how do I implement this in HDL code using some primitives? I need to design a 36-bit Wide by 512 Deep 18KB FIFO. Is it possible to do so in the SOPC buider? If so, pointers would be greatly appreciated.
Vinod.
no modelsim 6.5 AE(altera edition)
So which Modelsim[/I][/I] you are using then?
ModelSim ALTERA STARTER EDITION 6.5e
You can do it on the megawizard and then integrate inside of the SOPC with the "add component"
