Programmable Devices
21611 Discussions
FPGA Design Flow for Altera
Hi all,
I am looking for a document that describes exactly the design flow working with a FPGA of altera (from Design Entry to Device Programing), and explanations about every stage.
I found this document that compare between Altera and Xilinx
altera.com/literature/an/an307 .pdf
but it focus on the comparetion between those two and not explanations about the Altera stages.
and i found this one
altera.com/literature/hb/qts/qts_qii5v3_01 .pdf
but again no any explanations what every satge it's for
Thank you for your assist
Eddie
Hi Eddie,
I can suggest these three links.
This are some free online trainings where you can start with:
http://www.altera.com/education/training/curriculum/fpga/trn-fpga.html (http://www.altera.com/education/training/curriculum/fpga/trn-fpga.html
This is a side with all PDF documents that describe how to use the Quartus II development environment:
http://www.altera.com/literature/lit-qts.jsp (http://www.altera.com/literature/lit-qts.jsp
And this is the Quartus II build in help:
http://quartushelp.altera.com/11.0/ (http://quartushelp.altera.com/11.0/
Mathias
Thank you very much
