Hi all,
I am looking for a document that describes exactly the design flow working with a FPGA of altera (from Design Entry to Device Programing), and explanations about every stage. I found this document that compare between Altera and Xilinx altera.com/literature/an/an307 .pdf but it focus on the comparetion between those two and not explanations about the Altera stages. and i found this one altera.com/literature/hb/qts/qts_qii5v3_01 .pdf but again no any explanations what every satge it's for Thank you for your assist EddieLink Copied
Hi Eddie,
I can suggest these three links. This are some free online trainings where you can start with: http://www.altera.com/education/training/curriculum/fpga/trn-fpga.html (http://www.altera.com/education/training/curriculum/fpga/trn-fpga.html) This is a side with all PDF documents that describe how to use the Quartus II development environment: http://www.altera.com/literature/lit-qts.jsp (http://www.altera.com/literature/lit-qts.jsp) And this is the Quartus II build in help: http://quartushelp.altera.com/11.0/ (http://quartushelp.altera.com/11.0/) Best Regards, Mathias- Mark as New
Thank you very much
