21588 Discussions
FPGA-to-HPS SDRAM Interface blocks whole HPS
I have configured in QSYS f2h_sdram0 as Avalon-MM Bidirectional with a width of 64 bits.
Whatever I connect to this interface, blocks the HPS when I run "run bridge_enable_handoff" in the uboot console.
( Tried the SGDMA which freezes instantly, the NIOS II core which freezes upon a RAM access... )
Preloader and uboot are of course regenerated each time I change the design.
What can be the reason of this behaviour? Misconfiguration of pin assignments to the RAM in Quartus?
But Linux seems to work on the HPS.
Hannes
Edit: With security enabled at least no freeze with the SGDMA.
Edit2: If I forgot to mention something important, please tell me.
When frozen, everything on the f2h_sdram0 is set to 0 (data address, data_burstcount, data_byteenable, data_writedata, data_readdata)
Is this important? Is there anything I can test using Signaltap?
Has nobody any idea where I could start looking for the error?
If you are lacking information, tell me ;)
I have a similar problem. The ARM freezes not after enabling the bridges but at the first read access from the FPGA side to the SDRAM. After a cold reset all works fine and no freezes are seen. That happens only after a power-up.
Philipp
How have you made the waitrequest of the SDRAM interface falls to 0.
I added an SDRAM interface on HPS for the FPGA, but the waitrequest stays at 1.
Is anybody can help me ?
Thanks in advance.
I just solved a similar issue. Try burning the sof file first before booting Linux. Once the FPGA is configured, press the WARM reset button to boot Linux. The preloader should automatically configure all the required HPS registers on bootup. From my experience, you cannot properly configure the HPS SDRAM controller registers while Linux is running. This has to be done by the preloader on bootup.
Hope this helps!
--- Quote Start ---
Hope this helps!
--- Quote End ---
Indeed, if the .sof is loaded before booting linux, that works fine.
Is someone got a solution to avoid rebooting linux each time you what to try some codes?
And why we need to do that? preloader & uboot aren't here to manage intelligente booting??
Nico
If you let the ARM automatically configure the FPGA during boot, then you don't need to do the above steps! But I don't understand why this is so.
Well, when i let booting the arm first, then i program fpga frabric i cant read/write data to DDR3. :/
Oh, that's not what I meant. If you automatically configure the FPGA via u-boot: (http://www.rocketboards.org/foswiki/documentation/gsrd131programmingfpga#fpga_configuration_from_u_45boot) , you would not need to do the warm HPS reset step! :)
Okok, thanks for the hint. I'll try this :).
No problem! Works like a charm for me!! :)
Hey! Now works fine for me too :).
But i really don't understand why we need to do that.
Anyone knows???
Is that the "device tree" can help ?
Nico
I wonder if it would also work if the FPGA was configured from Linux. You would need to wait for configuration to finish, enable the FPGA-to-HPS SDRAM bridge, and only then make an access from the FPGA.
