21611 Discussions
Fpga Image Display
Hi
I wanna know if it possible to store an image file in FPGA - Spartan3 and then load it to the monitor screen as display?
If yes, how do I do that?
Thank u
Spartan 3 is a Xilinx device, you need a suitable Altera FPGA.
It depends on the size of the image, you might need external memory.
That's a bit of an open-ended question :-)
Blocking out your requirements first. At the very least you'll need a display driver, so I'd start there. It's very straightforward and will allow you to experiment with different display modes / refresh rates. Once you've got a stable display, figure out how / what you want to display.
-Mux
