21615 Discussions
Frame Buffer VHDL Template
Hello every body,
I'm trying to code a frame buffer using VHDL to perform some operation on an entire frame then store the result into DDR2 memory.
I used the Avalon MM Master VHDL Template but I didn't manage to make it run as desired
Can anyone provide me with a Frame Buffer VHDL Template ??
Thank you for your help
why not post what your code and tell us whats wrong?
Hi and thank you for responding.
I used the Avalon MM Master VHDL template and a custom core that enable the master when there is a valid data:
a simple Avalon ST Interface which enables the master using this code :
PROCESS (CLOCK,RESET) IF CLOCK'EVENT AND CLOCK='1' THEN IF AST_DIN_VALID = '1' THEN IF AST_DIN_SOP = '0' AND AST_DIN_EOP = '0' THEN ENABLE = '1'; ELSE ENABLE = '0'; END IF; END IF; END IF; END PROCESS; PROCESS (CLOCK,ENABLE) BEGIN IF ENABLE = '1' THEN --START the master: avs_csr_write <= '1'; avs_csr_address <= "00"; avs_csr_writedata <= "00000000000000000000000000000001"; DATA_To_Write <= AST_DIN_DATA; ELSE avs_csr_write <= '0'; avs_csr_address <= "00"; avs_csr_writedata <= (others => '0'); DATA_To_Write <= (others => '0'); END IF; END PROCESS;
and the master template :
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity simple_example is port ( -- clock interface csi_clock_clk : in std_logic; csi_clock_reset : in std_logic; -- read master avm_read_master_read : out std_logic; avm_read_master_address : out std_logic_vector (31 downto 0); avm_read_master_readdata : in std_logic_vector (31 downto 0); avm_read_master_waitrequest : in std_logic; -- write master avm_write_master_write : out std_logic; avm_write_master_address : out std_logic_vector (31 downto 0); avm_write_master_writedata : out std_logic_vector (31 downto 0); avm_write_master_waitrequest : in std_logic; -- control & status registers (CSR) slave avs_csr_address : in std_logic_vector (1 downto 0); avs_csr_readdata : out std_logic_vector (31 downto 0); avs_csr_write : in std_logic; avs_csr_writedata : in std_logic_vector (31 downto 0) ); end simple_example; architecture a of simple_example is -- the FIFO component was generated using the Quartus II MegaWizard Plug-In Manager component example_master_fifo port ( aclr : in std_logic; clock : in std_logic; data : in std_logic_vector (31 downto 0); rdreq : in std_logic; wrreq : in std_logic; empty : out std_logic; full : out std_logic; q : out std_logic_vector (31 downto 0); usedw : out std_logic_vector (5 downto 0) ); end component; -- fifo instantiation signals signal fifo_read, fifo_write : std_logic; signal fifo_empty, fifo_full : std_logic; -- state machine states type read_states_T is (idle, running, stopping); type write_states_T is (idle, running); signal read_state : read_states_T; signal write_state : write_states_T; -- extra read master signals signal read_address : std_logic_vector (31 downto 0); -- the current read address signal words_read : std_logic_vector (8 downto 0); -- tracks the words read -- extra write master signals signal write_address : std_logic_vector (31 downto 0); -- the current write address -- CSR registers signal csr_status : std_logic_vector (31 downto 0); -- the status word that will be read from the status register signal csr_rd_addr : std_logic_vector (31 downto 0); -- the read start address register signal csr_wr_addr : std_logic_vector (31 downto 0); -- the write start address register signal csr_go_flag : std_logic; -- used to start the DMA (when logic 1) signal active_flag : std_logic; -- logic 1 if either state machines are active begin ------------------------------------------------------------------------------- -- FIFO INSTATIATION ------------------------------------------------------------------------------- fifo_inst: example_master_fifo port map ( aclr => csi_clock_reset, clock => csi_clock_clk, data => avm_read_master_readdata, rdreq => fifo_read, wrreq => fifo_write, empty => fifo_empty, full => fifo_full, q => avm_write_master_writedata, usedw => open ); read_FSM: process (csi_clock_clk, csi_clock_reset) begin if csi_clock_reset = '1' then read_state <= idle; read_address <= (others => '0'); words_read <= (others => '0'); elsif rising_edge (csi_clock_clk) then case read_state is -- IDLE -- When idle just sit and wait for the go flag. -- Only start if the write state machine is idle as it may be -- finishing a previous data transfer. -- Start the machine by moving to the running state and initialising address and counters. when idle => if write_state = idle and csr_go_flag = '1' then read_state <= running; read_address <= csr_rd_addr; words_read <= (others => '0'); end if; -- RUNNING -- Count reads, inc address and check for completion -- The read signal is held inactive by comb logic if fifo full so do nothing if fifo full -- also do nothing if waitrequest is active as this means signals need to be held when running => -- if waitrequest is active or fifo full do nothing, otherwise... if avm_read_master_waitrequest /= '1' and fifo_full /= '1' then read_address <= read_address + 4; -- add 4 per word as masters use byte addressing words_read <= words_read + 1; if words_read = 255 then -- 256 in total (255 previous plus this one) read_state <= stopping; end if; end if; when stopping => read_state <= idle; end case; end if; end process; -- read when in in running state and fifo not full avm_read_master_read <= '1' when read_state = running and fifo_full = '0' else '0'; -- simply write data into the fifo as it comes in (read asserted and waitrequest not active) fifo_write <= '1' when read_state = running and avm_read_master_waitrequest = '0' and fifo_full = '0' else '0'; -- this maps the internal address directly to the external port avm_read_master_address <= read_address; write_FSM: process (csi_clock_clk, csi_clock_reset) begin if csi_clock_reset = '1' then write_state <= idle; elsif rising_edge (csi_clock_clk) then case write_state is -- IDLE -- Just sit and wait for the go flag -- When the go flag is set start by moving to the writing state and -- set the address. when idle => if csr_go_flag = '1' then write_state <= running; write_address <= csr_wr_addr; end if; when running => if avm_write_master_waitrequest /= '1' and fifo_empty /= '1' then write_address <= write_address + 4; -- Masters use byte addressing so inc by 4 for next word end if; if fifo_empty = '1' and read_state = idle then write_state <= idle; end if; end case; end if; end process; -- the write signal is active if in running state and fifo not empty avm_write_master_write <= '1' when write_state = running and fifo_empty = '0' else '0'; -- this maps the internal address directly to the external port avm_write_master_address <= write_address; -- the fifo_read signal takes data from the fifo and updates it's output with the next word -- should be 1 when writing and not in waitrequest fifo_read <= '1' when write_state = running and fifo_empty = '0' and avm_write_master_waitrequest = '0' else '0'; -- control and status registers -- -- address map -- 00 control (write only) -- 01 status (read only) -- 10 read start address -- 11 write start address -- -- control register -- bit 0 : start control (pulse 1 to start) -- -- status register -- bit 0 : active flag (1 when DMA active) -- write control of read and write address registers csr: process (csi_clock_clk, csi_clock_reset) begin if csi_clock_reset = '1' then csr_rd_addr <= (others => '0'); csr_wr_addr <= (others => '0'); elsif rising_edge (csi_clock_clk) then if avs_csr_write = '1' then case avs_csr_address is when "10" => csr_rd_addr <= avs_csr_writedata (31 downto 2) & "00"; -- ignore 2 lsbs as this component only supports word aligned data when "11" => csr_wr_addr <= avs_csr_writedata (31 downto 2) & "00"; -- ignore 2 lsbs as this component only supports word aligned data when others => end case; end if; end if; end process; csr_go_flag <= avs_csr_writedata(0) when avs_csr_write = '1' and avs_csr_address = "00" else '0'; -- readdata mux active_flag <= '0' when read_state = idle and write_state = idle else '1'; csr_status <= "0000000000000000000000000000000" & active_flag; read_mux: process (avs_csr_address, csr_status, csr_rd_addr, csr_wr_addr) begin case avs_csr_address is when "10" => avs_csr_readdata <= csr_rd_addr; when "11" => avs_csr_readdata <= csr_wr_addr; when others => avs_csr_readdata <= csr_status; end case; end process; ------------------------------------------------------------------------------- end a;
I don't knwo what's wrong ! I actually can't tell what data is written in the memory !
I don't know how to map the DATA_To_Write signal because I can't figure out what data is written to the memory !
Thank you.
where is the testbench?
