21611 Discussions
GPIO over HSMC on Altera DSP Development Kit, Stratix V Edition
Hello all,
What is the simplest way to connect an USB-to-UART module to the board in subject that have only HSMC connector?
Thank you
I assume you mean the low-level UART signalling - is that right?
There's no 'easy' way to do anything with the HSMC connector without a mating PCB. However, you can get hold of the mating half of the connector (samtec asp-122952-01 (https://www.google.nl/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahukewjvwm7b9djkahxcurqkhdxyciiqfggfmaa&url=http%3a%2f%2fsuddendocs.samtec.com%2fprints%2fasp-122952-01-mkt.pdf&usg=afqjcnhueobffx5i0kptzhq7qivpv5aagg)) and solder wires to it. Far preferable (and less risky) to soldering wires straight to your dev board.
Cheers,
Alex
There is an adapter HSMC to pin header 2.54mm out of there ? Soldering is not an option for these boards :)
Some dev kits (eg - cyclone v soc development kit (https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-soc.html)) refer to a "HSMC breakout board" that's included with the kit. So, yes. There is such a thing.
Also, the "altera jesd204b ip core and ti dac37j84 hardware checkout report (https://www.google.nl/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahukewi5ldk4-tjkahwktxqkhdgfdoeqfggqmai&url=https%3a%2f%2fwww.altera.com%2fcontent%2fdam%2faltera-www%2fglobal%2fen_us%2fpdfs%2fliterature%2fan%2fan719.pdf&usg=afqjcnehtcn_k_ymwa3e52r7y-tlrzrqww)" discusses it for a Stratix V dev board - see pic on page 2.
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
Thank you very much
