21592 Discussions
Ground noise when switching output
Karunakaran
HI
    When am switching any output Ground is bouncing 400mV 3 to 4 rings... is there any guidelines to reduce this
Ash_R_Intel
Please let us know which FPGA device you are targeting to.
You may refer to documents available:
  • AN-731: Simultaneous Switching Noise Guidelines for Intel Cyclone 10 LP, Cyclone IV, and Cyclone III Devices
  • Device design guidelines
  • AN 75: High-Speed Board Designs
  • Pin connection guidelines
Regards.
Karunakaran
Targeting to Max 10 10M08SAU169I7G
ak6dn
Valued Contributor III
How are you measuring that 400mV noise on your ground? What is the test lead setup into the oscilloscope input?
A less than optimal probing setup can induce false noise into your measurement.
You must be probing 'ground' with respect to 'ground', correct? But where are these two points located?
Ash_R_Intel
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
