Programmable Devices
21600 讨论
HBM2 Core clock can not work above 250M Hz
BQi
初学者
882 次查看
1SM21BHU2F53E2VG
core clk work in 250M Hz,read and write HBM2 no problem
if we change the work freq to 275M,the RW verification would be wrong. the test bench is self design prbs verify program,we found 2-5 error per test,the target would be 350M Hz
we found core clock is 370M Hz in ip userguide
0 项奖励
2 回复数
Deshi_Intel
主持人
773 次查看
If you refer to HBM2 user guide doc page 21 - core clock frequency explanation :
I am not sure where do you see the 370MHz spec but that most likely is theoretically max supported spec but it still depends on user design timing closure to determine the achievable Fmax.
dlim
0 项奖励
Deshi_Intel
主持人
773 次查看
HI,
I don't hear back from you after my feedback explanation.
Hopefully I clear your doubt.
For now, I am setting this case to closure.
dlim
0 项奖励
回复
