21611 Discussions
Help for counter programme
Design a 4-bit up/down counter with synchronous counting and asynchronous master reset. Write a VHDL design description of the counter based on the following criteria:
a) The counter increments or decrements on a negative clock edge only if its active-LOW enable
b) The master reset (MR) is an active-HIGH input that resets the counter to 0000 state.
c) The count outputs are Q3Q2Q1Q0 where Q0 is the LSB and Q3 is the MSB.
d) For up counting, a LOW at the UP_DW input. A HIGH at UP_DW input causes the counter to decrement.
The people are not here to make the homework of students.
If you have a problem with a specific part, explain what you did and where you are blocked.
so far i have this but i am not sure if i am doing the right thing.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity mini is
port ( en, m_reset, updown, clk : in std_logic;
q : out std_logic_vector (3 downto 0));
end mini;
architecture flow of mini is
signal mini :unsigned (3 downto 0);
begin
process ( en, m_reset, updown, clk )
begin
if (en = '1' and m_reset = '1')
then
q <= "0000");
elsif(en = '0' and m_reset = '1')
then
q <= "0000");
the enable has to be inside the clk edge detect for it to work properly.
i don't get what u mean by enable has to be inside clk edge
currently, you have set a reset whenever m_reset = '1', you have 2 if branches with enable in them, one for when enable is '1' and one when en is '0'. These branches are actually the same thing as the only important signal is m_reset = '1'.
as for the clock, you want the following code:
elsif rising_edge(clk) then if en = '1' then --check count direction and count end if; end if;
this is what i have so far .
library ieee;
entity mini is
port ( en, m_reset, UP_DW, clk : in std_logic;
end mini;
signal count_sig :unsigned (3 downto 0);
begin
process ( en, m_reset, UP_DW, clk )
begin
then
count_sig <= "0000";
then
count_sig <="0000";
elsif falling_edge (clk) and UP_DW = '0'
then
count_sig <= count_sig +1;
elsif falling_edge (clk) and UP_DW = '1'
then
count_sig <= count_sig -1;
end if;
end process;
q <= std_logic_vector (count_sig);
end flow;
how to make the altera board show hex from " A to F " ??
