21615 Discussions
Help me!! How to Configure EP3C25E144A7 (Cyclone III) with Fast Active Serial ?
https://alteraforum.com/forum/attachment.php?attachmentid=13642&stc=1
I want to Configure for chip EP3C25E144A7 with Fast Active Serial Fast (AS Fast POR), Help me to setup MSEL pins ? Thank you very much!!
quote:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahukewj688dg7evtahxgzlwkhbuuciqqfggumae&url=https%3a%2f%2fwww.altera.com%2fliterature%2fhb%2farria-10%2fa10_config.pdf&usg=afqjcnfkvt6xstwoxe2mcnpx9lmjstiyyw&sig2=ukd7-oxb4xzumkni_17mtq
"Smaller Cyclone III devices or package options (E144, M164, Q240, F256, and U256
packages) do not have the MSEL[3] pin. The AS Fast POR configuration scheme at 3.0-
or 2.5-V configuration voltage standard and the AP configuration scheme are not
supported in Cyclone III devices without the MSEL[3] pin. To configure these devices
with other supported configuration schemes, select the MSEL[2..0] pins according to
the MSEL settings in Table 9–7".
"FPP configuration is not supported in the Cyclone III E144 device package of Cyclone III devices"
you can't:
--- Quote Start ---
--- Quote End ---
The quoted statement is at least misleading. The packages without MSEL[3] are apparently bonding MSEL[3] to MSEL[2] pin, leaving only the below listed configuration options:
https://www.alteraforum.com/forum/attachment.php?attachmentid=13643
