21611 Discussions
Help!! need help for VHDL car detect system.
hey guys, i'm new with vhdl and i have to write the following programm, and i need help.
1.To detect number of car.
2.output s is the current number of car.
3.output a is the previous number of car.
4.to load the the previous number of car into the system when an active-low load input is activated.
5.led to light when 64 cars is detected.
I have problem on the load part so i hope u guys can enlighten me. below are some parts i have done. Thanks:)
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity project is
port ( sensor : in std_logic;
reset : in std_logic;
load : in bit;
s : out std_logic_vector (5 downto 0); --current number
a : out std_logic_vector (5 downto 0); -- previous number
led_on : out bit);
end project;
architecture flow of project is
signal count_sig: unsigned (5 downto 0);
begin
process (sensor, reset, load)
begin
if (reset='1') then
count_sig <= "000000";
elsif rising_edge (sensor) then
count_sig <= count_sig+1;
end if;
end process;
s <= std_logic_vector (count_sig);
end flow;
usually, you can just store it in an internal register:
if load = '0' then
a <= count_sig;
end if;
or some other stored version of count_sig.
I am concerned you are not using a real clock. Using an input as a clock (by looking for the rising_edge. can cause timing problems.
thanks..i will try it but can elaborate more on the clock cause i dont really understand.
hey i hv error after trying tat..
"Error (10476):type of identifier "count_sig" does not agree with its usage as "std_logic_vector" type"
what does this error mean??
thanks
