- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Now i get (console output) always the same value, nothing changes.. Also not if i try to get data from other geisters. So i believe i do something wrong, but i don`t know what.. or where to start searching. Can anyone support me on that?
My first step is just to get something, regardless of which data exactly, compensation parameter etc..
There is communication (oscilloscope), but nothing correct.
Find in the attachment screenshot of:
- QSYS
- NIOS c code
- NIOS c code
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Roman,
Can you share the design?
Your driver & Qsys system looks fine, Need to check the software side.
Anand
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Roman,
Okay,
For debugging can you try to read slave device address using alt_avalon_i2c_master_target_get.
Refer below link for API example.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf
Anand
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Anand
With the code in the attachment i get the following output:
Hello from Nios II!
targetadress 0x0
Error
Read chip ID: Read chip ID: Read chip ID: Read chip ID: Read chip ID: Data
Data
Data
Data
so it seems he even do not set the target address 0x76.
When i use the oscilloscope, there is no communication on the pins.
Thank you!
Roman
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Roman,
Is your BME280 SDO pin connected to the ground? check hardware connectivity.
Try to read the slave address without writing it.
Anand
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Anand
Oh i found the wiring issue... (unbelivable :( )
However, now i`m back at my initial problem, that the slave sends me some data that i am not expecting.
In the attachment is an oscilloscope picture, communication via NIOS2. The Slave sends me wrong data, but i a don`t know why and how i can control that from NIOS. (An osci picture from an working communication via arduino is in my first post)
I thought it is a missing initialization step but i can`t find any difference to the examples from Bosch.
alt_u32 txbuffer[0x200];
alt_u32 rxbuffer[0x200];
txbuffer[0] = 0xFA; //MSB
txbuffer[1] = 0xFB; //LSB
txbuffer[2] = 0xFC; //XLSB
while (1)
status = alt_avalon_i2c_master_tx_rx(i2c_dev, txbuffer, 1, rxbuffer, 3, ALT_AVALON_I2C_NO_INTERRUPTS);
usleep(1000000);
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- Temperature data may be randomly changing better read some other register.
- The tx buffer contains the 1-byte address, Is address (FA)correct ???
it should be 2 bytes FA & FB for temperature data.
Instead of reading temp data, read chip id and check if you are getting expected output for debugging.
Buffer[0]=D0;
alt_avalon_i2c_master_tx_rx(i2c_ptr,buffer,1,buffer,1,0);
Anand
