Programmable Devices
21615 Discussions
High-speed LVDS Cyclone10 LP
Majo
Does it possible to use ALTLVDS_RX/TX IP cores in Cyclone10 LP for 1GbE through SGMII interface. I've tried to make a test project but got an error that max transmitted speed is 840 Mbps.
Is there no chance to use it for 1250 Mbps?
AqidAyman_Intel
Thank you for reaching out Intel FPGA Community.
You can refer to the datasheet where it has outlined the High-Speed I/O Specifications.
Refer to this link https://www.intel.com/content/www/us/en/docs/programmable/683251/current/high-speed-i-o-specifications.html
Aqid
Majo
Thank you for your response. I've got a such result like in a picture bellow. Is it the top limit?
AqidAyman_Intel
Yes, it is the maximum speed as in the datasheet.
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
