21611 Discussions
Hot to create an Internal Memory Initialization (.hex) File in NIOS ?
I'm a beginner in Nios II software development.
I am using Altera Quartus 14.0 web edition, the Qsys and the Nios II SBT for Eclipse, and device family is Cyclone V.
I need to generate the internal Memory Initialization (.hex) File in NIOS but i don`t know how to generate Memory Initialization folder inside Software Directory [NIOS II] ? whereas Memory Initialization folder contains .HEX file, qip file and spd file.
Steps to create memory initialization files in the Nios II Software Developer's Handbook. in which workspace i need to follow the below steps :
1. Right-click the application project. [Which will indicate application project ?]
2. Point to Make targets and click Build to open the Make Targets dialog box.
3. Select mem_init_generate.
4. Click Build.
5. Add the .qip (meminit.qip) file to the Quartus II project.
Can anyone explain me the flow that where should i need to follow the above steps?
It is (Built-in tool) eclipse project, right click on the project folder(Not on the project BSP folder).
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
