21611 Discussions
How can I Preserve the Fitter Result of single module in a whole design?
SYiwe
There're several modules in my design, one of them(module A) achieves design goal after the latest compilation.
So I want to prevent the Fitter result of module A from being changed in the future, while the other modules' source file will be modified.
The point is, I didn't set module A as a partition before the latest compilation.
Is there any way that I can keep the Fitter result of module A completely unchanged?
Thanks, regards.
RichardTanSY_Altera
Hi, you can implement Design Partitioning to preserve the synthesis or fitter result.
You can refer to the reference guide below:
Intel® Quartus® Prime Pro Edition User Guide Block-Based Design
Video:
Incremental Block-Based Compilation in the Intel Quartus® Prime Pro Software: Design Partitioning
