21595 Discussions
How can I make comunication between dsp and Dual-Port Ram internal FPGA?
I want to comunicate dsp with Dual-Port Ram internal FPGA.Because there are two Dual-Port Ram in FPGA, and one to read,the other one to write.Now the databus is bidirectional,so I must transform the bidirecional databus to two bus,the one is in,other one is out.
I have tried and emulated ,but it didn't work correctly.the databus (DATA1 )output allways keep "XXXX".
Thank you for any help!
This is the code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
ENTITY busTrans IS
PORT
RESET :IN STD_LOGIC;
VMECS_N :IN STD_LOGIC;
WRITE :IN STD_LOGIC;
READ :IN STD_LOGIC;
ADDRESS :IN STD_LOGIC_VECTOR(11 DOWNTO 0);
DATAbus :INOUT STD_LOGIC_VECTOR(23 DOWNTO 0);
DATA1 :OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
DATA2 :IN STD_LOGIC_VECTOR(15 DOWNTO 0);
------other
RAM1EN :OUT STD_LOGIC ;--ram1 enable
IOCS_N :OUT STD_LOGIC
END busTrans;
ARCHITECTURE a OF busTrans IS
BEGIN --begin ARCHITECTURE
p1: PROCESS (RESET,VMECS_N,ADDRESS,DATAbus,DATA2)
BEGIN --begin process
if(RESET='1') then
IOCS_N <='1';
elsif(VMECS_N='0') then --
IOCS_N <='0'; --
if(ADDRESS(11 downto 6)= "000000") then
RAM1EN<='1';
DATA1(15 DOWNTO 0)<=DATAbus(15 DOWNTO 0);
elsif(ADDRESS(11 downto 6)= "000001") then
RAM1EN<='0';
DATAbus(15 DOWNTO 0)<=DATA2(15 DOWNTO 0);
end if;
else
RAM1EN<='0';
end if;
END PROCESS p1;
END a;
In your process (Which is an Asynchronous process) the signals DATAbus and Data1 and IOCS_N are not assigned on all paths though the logic. This will infer storage (Latches). I imagine this is not what you intend.
i.e. what is the value of RAM1EN when Address is all ones?
I suggest you either rewrite your code as a synchronous process or if you just want combinatorial logic then ensure all signals are assigned in all paths
Thank you very much!
I will rewrite my code.
