hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Programmable Devices
21322 讨论
How do you choose if you use REFCLK T or B for PCIe?
fgfasfafgfdhagdszfea
1,251 次查看
I'm working on the PCIe for a Cyclone 10 GX 10C085 and I have a question regarding the REFCLK for the PCIe.
How do I know if the reference clock should go in REFCLK_GXBL1C_CHT or REFCLK_GXBL1C_CHB (T or B)?
0 项奖励
5 回复数
skbeh
员工
1,236 次查看
The PCIe Hard IP placement always starts at bottom transceiver block.
T: Top
B: Bottom
So please assign the pcie refclk pin to the Bottom location REFCLK_GXBL1C_CHB (B)
0 项奖励
1,231 次查看
Thanks, that is what I will do! Is there anywhere specific in the documentation that I could have found that information?
Is REFCLK_GXBL1C_CHB required (REFCLK_GXBL1C_CHT wouldn't work) or is it just preferred (easier fitting or something like that)?
0 项奖励
skbeh
员工
1,192 次查看
I repost the reply.
You can download and refer to the Device pin-out file of '10CX085' from below link:
https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/lit-dp.html
It is required to use REFCLK_GXBL1C_CHB.
Inside the pin out file:
0 项奖励
skbeh
员工
1,218 次查看
0 项奖励
1,197 次查看
Did you post some images? I can't tell for certain, but it looks like the images aren't showing up in the post.
0 项奖励
回复
