Programmable Devices
21604 Discussions
How to Set environment valiable on LINUX plateform for Quartus
Dear Friends,
I am trying to work on Linux RHEL-6 plate-form for Quartsu 9.1SP2.
now i am trying to set environmental variable using following command
export PATH=$PATH:/opt/altera9.1sp2/quartus/bin
and then on command prompt i write "quartus" and quartus starts
but if i close the command prompt and again reopen command prompt an write "quartus", it wont run...it seems my environmental variable not written.
so how do i set my environmental variable permanently.
regards
kaushal
Your shell will read commands from one (or more) files files everytime it starts.
Its probably bash and almost certainly reads .bashrc from your home directory.
To avoid major mishaps keep the window with the editor open until you've got it working!
thanking you for your reply ...
ok then i how do i run nios-eclipse ?, as it is not running the way i am running quartus
