21602 Discussions
How to Setup Output Using GPIO
[h=2][/h]usually i construct logical circuit then assign input switch n push button and for output using led and seven segment.... Now i want try GPIO but i dont know how to use and assign pin planner.. I need guide..plz
GPIO is quite common IP. Any eval kit or board reference design with NIOS would walk you through http://www.alterawiki.com/wiki/bemicro_max_10 .
Any eval board reference design with NIOS would walk you through how. Eg,http://www.alterawiki.com/wiki/bemicro_max_10
Use the pin planner provided by Quartus IDE and the user manual for your board, to decide which pins are mapped to which GPIO pins.
Later update the preloader and device tree, and then you should have it working.
