21602 Discussions
How to address two sperate timing constraints in the Arria 10 IO to drive ADC3224 chip (100MSPS)
JoelCaruso
1st Quartus cannot fit customers timing constrain condition. *as showcased in file*
2nd, Arria 10 cannot fit the timing internally inside FPGA (from DDIO IP output to registers). We checked the previous version of this IP. The IP will output data at positive edge of the clock. But now in version 18.1, the data will be output at negative edge of the clock. That means the setup condition is more strict.
How can the engineers address? please review file.
Can you please provide an email address to share the project files with and without PLL directly?
KhaiChein_Y_Intel
I have sent an email to you. Please let me know if you do not receive.
KhaiY
KhaiChein_Y_Intel
Do you have any updates?
KhaiY
JoelCaruso
Hi KhaiY - didn't see your email direct to me, however this issue was addressed by a FAE and solved. The answer was to use PHY Lite for Parallel Interfaces Intel FPGA IP a free IP. Which would perform at a higher frequency than GPIO.
