21608 Discussions
How to change datawidth of DMA Controller Intel FPGA IP
Jiayi_H_Intel
Hi expert,
I want to change the data width of read master and write master, but it seems there is no way to change it. Do you know how to change that?
Long time ago, I successfully changed it to 128bit and there is also a byte enable signal in write port.
Thanks!
sstrell
You probably just need to change a parameter.  Reopen the parameter editor for the IP (may be a .qsys or .ip file depending on if you're using Standard or Pro) and change the parameter.  Most IP like this and their parameters are documented here: https://www.intel.com/content/www/us/en/docs/programmable/683130/22-3.html
Jiayi_H_Intel
But there nowhere to change it in parameter editor:
BTW, I am not using blackbox.
Jiayi_H_Intel
hareesh
https://www.intel.com/content/www/us/en/docs/programmable/683130/22-3/setting-up-dma-transactions.html
go through this document. if you see here quadword support 128 bit.
may i know which version did you used previously?
Jiayi_H_Intel
You can see my snapshot, I have already enabled quadword, but readdata is still 8 bit.
I am using Quartus 21.3 and 21.4.
BTW, you can check the "show signals" box in your picture to see the signal width. Is it a 128bit width?
hareesh
  • Byte (8-bit), halfword (16-bit), word (32-bit), doubleword (64-bit) or quadword (128-bit)
those are transfer type, there is no option to change width.
i want to know on which version you did those changes?
Jiayi_H_Intel
I used to use 21.3 to generate 128width.
"there is no option to change width" ---- I think it is not reasonable since the performance is too much low with 8 bit width.
Jiayi_H_Intel
hello,
I have replied your email for arranging a call, but I don't see feedback. Can you ping me directly? Thanks!
hareesh
Small doubt, in you previous DMA (128 bit support IP) can able to trans for 128 bits, because this ip design can support only 8 bit's only. did checked that?
Thank you,
Jiayi_H_Intel
Yes. It can transfer 128bits and worked perfectly well. I have also tested it on FPGA board.
You can double check with the IP I sent to you.
hareesh
hareesh
i discoursed with engineering team every one, telling we don't have option to vary the data width of DMA. i shared your platform design also, they telling you did changes in source code. Actually we are not able to give support for source code changing. if any problem is there in working of IP we can give support. sorry.
in DMA controller IP document you see functionality of DMA
https://www.intel.com/content/www/us/en/docs/programmable/683130/22-3/dma-parameters-basic.html
Thank you,
Hareesh B.
hareesh
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
