21602 Discussions
How to flash memory when power on Max 10 (10M02SC)?
TPham24
Hello everybody!
I'm Pham Tu Tai!
I used Cyclone 2 for my project. But i'm using Max 10 series (10M02SC) now.
I dont know how to flash memory for Max 10. Because Cyclone 2 use EPCS4 for programmable when every power on. However, Max 10 dont use EPCS devices.
I readed guidelines of Max 10 use CFM and UFM but i dont understand.
If you know. Please answer me!
Thank you.
ShafiqY_Intel
Hi TPham24,
MAX 10 device come with Internal Flash Memory. Usually it is enough to program design/project.
(when convert programming file(ie .pof file), select mode = "Internal configuration")
However, if you need extra memory space, you can use EPCQ-A device. You can follow the following KDB for more details how to program EPCQ-A device with MAX 10.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/embedded/2019/how-to-program-epcq-a-devices-used-in-an-max---10-design-.html
Hope this will help.
