Programmable Devices
公告
21615 讨论
How to measure distance between two data
名誉分销商 II
16,231 次查看
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them.
d(s1,s2)=(1+1+0+1+1)/(n^2/2)=4/12=0.33333
0 项奖励
51 回复数
名誉分销商 II
3,465 次查看
do you really calculate square root in HDL?
I recommend you to use NiosII CPU ( or other CPU )
and get result in software ( like C-language ).
but, you insist to get result in HDL.
there is IP-core such as ALTFP_SQRT ( and other floating-point functions ).
both way are tough for newbie.
let study.
0 项奖励
名誉分销商 II
3,465 次查看
hi akira
thanks for reply
first i want to know how to create table using vhdl,then calculate the distance between the position of each element in s1 and the position of the same element in s2 then find normalized distance
0 项奖励
名誉分销商 II
3,465 次查看
by distance you mean d(s1,s2) as per equation given. But what does this equation mean? what is n^2/2 = 12 ?? and what does 1+1+0+1+1 mean
0 项奖励
名誉分销商 II
3,465 次查看
you can create onchip(or external)RAM.
and you can create ram -initializ like following (this is verilog-HDL sorry)
reg [WORD_WIDTH-1:0]pattern_rom[0:2**ADDR_WIDTH];
initial $readmemh( "ROM_HEX_FILE.txt",pattern_rom);
reg [WORD_WIDTH-1:0]outbuff;
always @ ( posedge csi_clk )
begin
outbuff <= pattern_rom[reg_read_addr];
end
assign wir_read_data = outbuff;
ROM_HEX_FILE.txt is initial data of pattern_rom.
anyway, there is a way you can create table.
but I am not sure you really have big enough memory on your FPGA.
0 项奖励
名誉分销商 II
3,465 次查看
d(s1,s2) is the distance between the position of each element in s1 and the position of the same element in s2
which is 1+1+0+1+1=4 then divided by (n^2-1)/2 where n is the number of elements in table
sorry for not clear at first. i want to make a vhdl code for that
so i need help
0 项奖励
名誉分销商 II
3,465 次查看
--- Quote Start ---
so i need help
--- Quote End ---
So in the given case you have the given distances as 1+1+0+1+1 (n = 5) so distance = 1+1+0+1+1 = 4 then normalised to 5^2-1/2 i.e. /12
=.333
is n constant 5 always. How do you get the positions of 1,1,0,1,1? are these five inputs?
Once you are clear about the requirement then you can go for coding.
0 项奖励
名誉分销商 II
3,465 次查看
first n is not constant it depend on table element which is definitely changed .
second , the position of each element corresponding to the same element in the other table
i wrote a code put didn't know ,is it right? give a code for every element in table
library IEEE;
use IEEE.STD_LOGIC_1164.all;
package profile_A is
type A1 is array (0 to 4) of std_logic_vector( 23 downto 0);
constant table1:A1:= ("011010010110001101100001","011011010110010101110010",
"011000010110110101100101","011100100110100101100100","011001010111001001101001");
type A2 is array (0 to 4) of std_logic_vector( 23 downto 0);
constant table2:A2:= ("011011010110010101110010","011010010110001101100001",
"011000010110110101100101","011001010111001001101001","011100100110100101100100");
end profile_A;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use work.profile_A.all;
entity samples is
port ( s1:in A1;
s2: in A2;
clk:in bit;
distance:out integer);
end samples;
architecture Behavioral of samples is
signal d :integer ;
begin
process(clk,s1,s2)
begin
for idx in 0 to s1'length loop
if (clk='1'or clk'event) then
if s1(idx)=s2(idx)then
d <= idx-1;
end if;
end if;
end loop;
end process;
end Behavioral;
0 项奖励
名誉分销商 II
3,465 次查看
Judging from your code you assume S1/S2 are inputs each 24 bits. However I doubt it.
More likely you enter (n) elements each 24 bits wide into two rom tables (e.g. from a file).
Once you have these two roms then you read rom1 output and check each output against rom2 output until you find a match then the distance is
address2 - address1 then you perform your computation circuitry of adding all results * (n^2-1)/2
The divide by 2 is easiest(just discard 1 LSB from final result).
for n^2-1 use multiplier subtractor directly(multiply n * n) then subtract 1
for final division you will need a divider
0 项奖励
名誉分销商 II
3,465 次查看
thanks kaz , y really helped me
first i tried to make vhdl code for dual port ram because i will compare between two samples ..is it right thing???
but i have a problem when i tray to test the test bench is (all generics must take a default value) here is code i need your help...
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity bram_tdp is
generic (
DATA : std_logic_vector (0 to 6) ;
ADDR : std_logic_vector (0 to 6));
port (
-- Port A
a_clk : in std_logic;
a_wr : in std_logic;
a_addr : in std_logic_vector(6 downto 0);
a_din : in std_logic_vector(6 downto 0);
a_dout : out std_logic_vector(6 downto 0);
-- Port B
b_clk : in std_logic;
b_wr : in std_logic;
b_addr : in std_logic_vector(6 downto 0);
b_din : in std_logic_vector(6 downto 0);
b_dout : out std_logic_vector(6 downto 0)
end bram_tdp;
architecture rtl of bram_tdp is
-- Shared memory
type mem_type is array ( 6 downto 0 ) of std_logic_vector(6 downto 0);
shared variable mem : mem_type;
begin
-- Port A
process(a_clk)
begin
if(a_clk'event and a_clk='1') then
if(a_wr='1') then
mem(conv_integer(a_addr)) := a_din;
end if;
a_dout <= mem(conv_integer(a_addr));
end if;
end process;
-- Port B
process(b_clk)
begin
if(b_clk'event and b_clk='1') then
if(b_wr='1') then
mem(conv_integer(b_addr)) := b_din;
end if;
b_dout <= mem(conv_integer(b_addr));
end if;
end process;
end rtl;
0 项奖励
名誉分销商 II
3,465 次查看
sorry ,,, i found it
i should change
to
DATA : integer :=7 ;
ADDR : integer :=7;
but i ask you if i can enter data as in the table i mean word (asd,sdf,rto....etc)
and is it right to use dual port ram
thanks a lot
0 项奖励
名誉分销商 II
3,465 次查看
Let me suggest an easier way.
assume S1,S2 are inputs (8 bits wide each). Use two shift registers with (n) stages. Let the data S1,S2 shift through till the end and freeze the shift register then you can compare each value with others for equality and distance becomes index difference. For example if s1_shift(0) = s2_shift(3) then distance is 3-0 = 3 and so on.
To code for shift register do this in a clocked process.
s1_shift(0) <= s1; for i in 1 to n-1 loop -- n declared somewhere s1_shift(i) <= s1_shift(i-1); end loop;
the code for checking equality can also be done in a loop to check say index(0) of s1 with indices 0 to n-1 of s2 then index(1) of s1 with indices 0 to n-1 of s2 and so on.
0 项奖励
名誉分销商 II
3,465 次查看
Regarding those strings like asd,sdf etc. what is't and what does your tables actually mean
for example MER is 255 in table1 and is 215 in table2 then you look for MER (not the number next to it), what is it, are you clear about it, I am not
0 项奖励
名誉分销商 II
3,465 次查看
OK .... actually this table is some samples taken from user A represent in trigraphs from any text he wrote and digit behind it be the time he take to type those trigraphs such as ( acs--125 ms, asd--200 ms ........) build a sorted table1(S1) ,(sorted according to the time), consists of these data and table2 (S2) of the same trigraphs
compare between these samples and found the distance between the same trigraphs from the two samples i should make it in vhdl code , but you make me in doubt what i use ram or registers.
regarding you code about register how i can find index in vhdl code.
0 项奖励
名誉分销商 II
3,465 次查看
--- Quote Start ---
--- Quote End ---
The index of register would be the loop
for i in 0 to n-1 loop for j in 0 to n-1 loop if s1_shift(i) = s2_shift(j) then d(i) <= j-i; end if; end loop; end loop;
you will get d(0) ~ d(n-1) as distance then you compute it further
you need to get the type conversion right and test the code idea.
0 项奖励
名誉分销商 II
3,465 次查看
i can't do this code in memory like register
i try but failed
process(addr_a)
begin
for i in data_a'range loop
for j in data_a'range loop
if data_a(i) = data_b(j) then
d <= addr_a - addr_b;
end if ;
distance <= d;
end loop;
end loop;
0 项奖励
名誉分销商 II
3,465 次查看
--- Quote Start ---
i try but failed
process(addr_a)
begin
end if ;
distance <= d;
end loop;
end loop;
--- Quote End ---
The code I suggested was for shift register(not ram). even then you have to use d(i) not just d
if you want to use ram then use two rams one for s1 and one for s2 then subtract addresses without the need for loop
0 项奖励
名誉分销商 II
3,465 次查看
--- Quote End ---
actually i use dual port ram for s1 and s2 and make this code
if data_a = data_b then
distance <= addr_a - addr_b;
end if;
the big problem is if and only if data_a = data_b at the same clock cycle not for all data index ,you understand me
0 项奖励
名誉分销商 II
3,465 次查看
use two single port rams one for s1 and one for s2 then address subtraction applies.
If you also want to write inputs to the rams then use two dual port rams again one for s1 rd/wr and one for s2 rd/wr.
It really depends how you are going to get your inputs s1/s2 in the first place which you haven't told us yet.
0 项奖励
名誉分销商 II
3,465 次查看
may i said in another way,when i tried to match between every element in mem1 with every element in mem2 such as
if data_a=data_b then
d<=addr_a - addr_b;
it happened if data_a=data_ b in the same clock cycle not for all mem data i/p
0 项奖励
名誉分销商 II
3,354 次查看
how can i make the match between the two rams.
i search but not found any thing help me
0 项奖励
回复
